Reply 20 of 24, by shevalier
- Oldbie
momaka wrote on 2025-07-18, 07:35:But this has nothing to do with the industrial PSUs I'm talking about. Most of them come with 5 screw terminals: AC input (L & N), ground, and output (+) and (-). The ground terminal is highly RECOMMENDED, but OPTIONAL. It is isolated from the PSU output terminals, but you could reference one of these to it, if desired.
The B2B sector (industry) implies the presence of skilled employees, due to which it consciously goes for reducing electrical safety and cost.
And then once a year the housewife gets an electric death in the shower because she bought a charger without galvanic isolation on AliExpress.
It's better not to do that.
momaka wrote on 2025-07-18, 07:35:You mean discontinuous forward design. (Flyback is just a term people commonly use for it, though despite not being technically […]
You mean discontinuous forward design. (Flyback is just a term people commonly use for it, though despite not being technically accurate.)
Well, not always.
You can have both continuous or discontinuous designs with UC384x current-mode PWM controllers. The easiest way to tell which one you're dealing with is if there is a large inductor (usually toroidal, like on standard group-regulated ATX PSUs) on the output after the rectifiers (but before the output caps) or not.
No output inductor = discontinuous design **
Output inductor/toroid present = continuous design.** except half-bridge LLC designs - these have no output inductor either... but then again, these won't use a UC3842-style current-mode PWM controller either, so not really worth mentioning this here. 😁
Well, we are talking about AC/DC power supplies, not step-down converters, like this
https://sector.biz.ua/docs/power_supply_schemes_8/350T.jpg
discontinuous - definitely "yes", forward - I'm not sure, accumulation and transfer are separated in time, aren't they?
Sorry, I was wrong.
There will always be a pervert using UC38хх in an asymmetrical forward half-bridge.
https://320volt.com/wp-content/uploads/2011/0 … t-sbl3040pt.gif
Now I've seen everything, and you won't be able to surprise me anymore. 😀
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
