Reply 20 of 35, by egbertjan
continuation of previous post
Here are the Speedsys images. I can clearly see that the L2 cache and memory are also slower with the Pentium Overdrive 83MHz than with the 486 DX2 66MHz. The CPU test is much faster with the Pentium Overdrive 83MHz. The video memory speed is also slower with the Pentium Overdrive 83MHz than with the 486 DX2 66MHz.
Pentium Overdrive 83MHZ
The attachment speedsys overdrive.jpg is no longer available
486 DX 2 66MHZ
The attachment speedsys 486dx2.jpg is no longer available
these are my bios settings.
The attachment 20260228_233354.jpg is no longer available
The attachment 20260228_233409.jpg is no longer available
The attachment 20260228_233430.jpg is no longer available
The Pentium Overdrive 83 MHZ performs slower than the 486 DX 2 66MHZ in all tests, except for Quake, where it gets 2 frames more
What else can I do to get the speed of the L2 cache, memory, and video memory to match the speed of the 486DX2 66MHz? Are there perhaps incorrect BIOS settings, or have I misplaced my jumpers? The jumper settings are set for a 486DX2 66MHz and I have a 33,33 MHz oscilator installed. Does anyone know if there's anything I can do about this, or is it because this motherboard doesn't support Pentium Overdrive 83MHz better?
Reply 21 of 35, by egbertjan
I measured the speed with a meter in the ISA slot with the Pentium Overdrive 83MHz and with the 486 DX2 66MHz. See the pictures.
With the Pentium Overdive 83MHZ
The attachment 20260301_140451.jpg is no longer available
with the 486DX2 66MHZ
The attachment 20260301_142041.jpg is no longer available
It seems like the Pentium Overdive 83MHz significantly reduces the speed to the ISA slot. I have no idea why. Could I have configured something incorrectly in the BIOS or with the jumpers?
Reply 22 of 35, by BitWrangler
That's weird, I wonder if it's setting the ISA clock divider by some dumb timing loop that thinks it must have a 40 or 50mhz bus CPU in there to get the same result it got from the POD.
Edit: yah numbers seem close enough that it has switched from a 1:4 divider to a 1:6
Reply 23 of 35, by rmay635703
This is a case where opening up all the hidden bios parameters is helpful.
Many old ibm bios operated in a stupid way where it only looked at raw clock speed to “automatically” set FSB parameters .
It’s probably slowing cache and memory as well using unnecessarily slow chipset timings.
Reply 24 of 35, by egbertjan
rmay635703 wrote on 2026-03-01, 15:22:
Can you let me know how I can open hidden bios parameters?
Reply 25 of 35, by Beerfloat
egbertjan wrote on 2026-03-01, 15:50:
You'll want to have a look at a tool called modbin, see here.
Reply 26 of 35, by Chkcpu
Hi egbertjan,
I agree with rmay635703 that enabling hidden BIOS options for ISA-bus clock would be the best solution. For your v2.06k Award v4.50 BIOS, the MODBIN tool from Award Software is the way to do this.
I used MOBIN on your v2.06k BIOS, but unfortunately it doesn’t have any hidden options for ISA clock control.
Looking in the disassembly listing I have of this BIOS, I only see automatic ISA clock control depending on the detected FSB speed.
As Bitwrangler suspected, the FSB speed detection must be confused by the POD 83 with its x2.5 multiplier and think it is running at more than 40MHz FSB. This would cause the BIOS to set a 1:6 divider for 50MHz FSB.
It will take me some time, but I will look in the BIOS code to see if I can fix this.
Groetjes, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 27 of 35, by Chkcpu
Hi egbertjan,
I believe I’ve found an alternate solution to your POD83/ISA-bus clock issue.
It appears that the old DOS chipset control program CTCHIPZ has a VT82C495.CFG file for the VIA chipset on the FIC 4386-VIO board. This VT82C495.CFG file comes complete with Macros for setting the ISA-bus clock directly.
Here is a copy:
The attachment CtChipz_VT82C495.zip is no longer available
From the DOS prompt (or from AUTOEXEC.BAT), use this command to set the FSB/ISA clock divider to 1:4
CTCHIPZ VT82C495 /BUSCLK4
The VT82C495.CFG file also has Macros for other dividers:
BUSCLK2 -> 1:2 for 16MHz FSB
BUSCLK3 -> 1:3 for 25MHz FSB
BUSCLK4 -> 1:4 for 33MHz FSB
BUSCLK5 -> 1:5 for 40MHz FSB
BUSCLK6 -> 1:6 for 50MHz FSB
BUSCLK8 -> 1:8 (not usable on the 4386-VIO)
BUSCLK10 -> 1:10 (not usable on the 4386-VIO)
BUSCLK12 -> 1:12 (not usable on the 4386-VIO)
Let us know if this solution helps with your issue.
Greetings, Jan
Reply 28 of 35, by egbertjan
Thank you Jan, right now I am rather buzy, I'll be back in a couple of days on this issue
Reply 29 of 35, by BitWrangler
Great find Jan!
I gotta remember that util for stupid OEM boards.
It is possible that the system will work with a 1:3, depending usually on how fussy network and sound cards are, they are usually the problem children above 10mhz, though it's usually over 12mhz that things get more difficult. The only time it's not those two suspects though is if you've got ancient VGA or I/O cards.
Reply 30 of 35, by egbertjan
I have tested CTCHIPZ.exe with BUSCLK4, which was rather successfull. The ISA-bus increased from 5.56 to 8.33 MHz. Speedsys shows that the speed of the videocard is now on the same level as it was with the DX2-66. Also the speed of the HDD increased, but not to the level with the DX2-66. The higher ISA speed did not result in a faster level2 chache, about 9 MB lower compared to the DX2-66. Aldo the DRAMis a little bit slower.
In all the benchmarks the Pentium Overdrive turns out to be about 25% faster than the DX2-66 after increasing the ISA to 8.33 MHZ.
Does anybody know if it is possible to increase the speed of the level 2 cache to the level with the DX2-66?
Cachetest DX2-66:
The attachment dx2 66 .jpg is no longer available
Cachetest Pentiumoverdrive 83MHZ:
The attachment overdrive.jpg is no longer available
Speedsys DX2-66:
The attachment dx2 66 2.jpg is no longer available
Speedsys Pentiumoverdrive 83MHZ ISA bus 8.33 MHZ
The attachment hddtest overdrive isa 8.33.jpg is no longer available
Speedsys Pentiumoverdrive 83MHZ ISA bus 5.56 MHZ
The attachment hhdtest overdrive 5.56.jpg is no longer available
Reply 31 of 35, by egbertjan
Speedsys Mem speed dx2-66
The attachment dx2 66 mem.jpg is no longer available
Speedsys Mem speed Pentiumoverdrive 83MHZ
The attachment overdrive mem.jpg is no longer available
Reply 32 of 35, by BitWrangler
I am wondering if it is due to the 0.5 in the multiplier, resulting in read, read, miss, read, read, miss...
Reply 33 of 35, by Disruptor
Hi egbertjan,
I have noticed a DRAM performance under par.
Have you tried to put DRAM timing control to "Fastest" ?
Does your system boot and execute DOSBENCH' Doom + Quake tests without any problems?
If it works stable, please post the results again (SpeedSYS cache chart).
Basically you'd go with your FSB
25 MHz --> Fastest
33 MHz --> Faster
40 MHz --> Slower
50 MHz --> Slowest
But I prefer to go one level faster, like Fastest with 33 MH, Faster with 40 MHz and Slower with 50 MHz. Slowest with experiments like 60 or 66 MHz on special boards with special processors like AMD 486 DX4/120 in x2 mode.
Reply 34 of 35, by egbertjan
On the picture you can see the BIOS-settings I used during the tests above. Fast is the highest possible setting for the DRAM Timing Control. There are only two options: normal and fast. The only options for the Cache Timing Control are: normal, fast and turbo.
The attachment 20260317_153543.jpg is no longer available
Reply 35 of 35, by rmay635703
egbertjan wrote on 2026-03-17, 14:43:
Did you test memory and cache speed for every setting slow to fast?
I had an old board where the settings were reversed, another where “optimal” was the fastest and another still where the speed settings were all identical and seemed to do absolutely nothing.
It’s possible that the automatic logic could be hard coded differently to the bios speed settings but it would take a lot of coding time for the wrong person.
