Please help me free up Conventional Memory
Reply 20 of 24, by wierd_w
Keep in mind that umbpci cannot enable the monochrome region as umb. Only C000-FFFF region is permitted, and b000 is outside that.
Again, if actual ram was there, it could be turned on with hiram.sys, but *NOTHING* is there on a modern rig.
It needs EMM386 or similar to map it in.
Reply 21 of 24, by Carrera
I am enjoying this thread way too much...
Reply 22 of 24, by C0deHunter
OK, many thanks for amazing responses to my original thread. I have a new build, and I have completely forgone Phil's Computer Lab MS-DOS 7.1 menu:
I have a clean, pristine config.sys and autoexec.bat
Would it be too much to ask if you kindly write a very minimal that allow 618KB+ conventional memory for my system?
I have TWO optical drives, Sound Blaster Audigy 2 ZS.
The user CRVS has a minimal one that works posted here:
Re: Installing DOS drivers on an Audigy2 ZS
But I am having trouble getting it to work.
Many thanks in advance!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 23 of 24, by keenmaster486
keenmaster486 wrote on 2025-09-25, 20:52:
Use JEMMEX instead of HIMEM+EMM386, and don't look back.
World's foremost 486 enjoyer.
Reply 24 of 24, by wierd_w
Again, the devil is in the details, and I need to see your 1mb memory map with no managers/drivers loaded, so I can give includes/excludes.
Jemmex does a decent job, but is not bulletproof.
