GTX 7xx or GTX 9xx for Windows XP?
Reply 20 of 30, by AaronS
For DX7 and earlier I have a Quadro FX600 PCI, I'm assured that Win98 will install and work on this MB, so the question was specifically for DX8 onwards. But yes there may be some DX8/9 games that might work better under 98, I can't imagine there being many though.
Reply 21 of 30, by vvbee
In compatibility a 2010s Radeon in XP is likely an improvement over an FX in 98. That comes back to the build of Radeon + 10 series, no one has come up with a downside or blind spot this build would have in the XP-Vista/7 range or a build that would do better. Add a PCI Voodoo of some version and passthrough to a Windows 9x VM for convenience and what else is left but the few speed sensitive DX games.
Reply 22 of 30, by AlexZ
Phenom II X6 1100T will not benefit from GTX 980. I had one and it got replaced by Vishera in AM3+ board. Vishera FX-8370 is about 20% faster than Phenom II X6 with broken turbo. If you do not fix the broken turbo it is only very slightly faster than Phenom II X4 955.
During my testing of AM2+, I identified GTX 670/770 as more than enough for Phenom II X4 955 to play Windows Vista/7 era games at max details in 1920x1080. If your focus is just Windows XP, you will be fine with GTX 660/760. I wouldn't really bother with GTX 980 and fixing driver. GTX 660/760 are so numerous and cheap that people give them out for peanuts. You can even request lower price for fun. If you find GTX 670/770 for the same price then go for that. I'm using GTX 780 in AM2+ only because I already have it as I needed it for benchmarking. I also have another GTX 980 (non Ti and Ti) collecting dust in drawer because it isn't necessary.
I'm not suggesting older cards, because for Phenom II X6 1100T it makes sense to eventually dual boot Windows Vista/7 as well. Phenom II X4 955 is not powerful enough to play games with Physics, Phenom II X6 1100T will have the same problem. There is major drop in FPS that makes it not worth it. You will need Intel 3770K for that.
GTX 980 really deserves Intel 3770K or at least very fast Vishera. I have also FX-9370 but it isn't installed yet until I determine how it compares with FX-8370 TDP wise at low frequencies as I would undervolt it and under clock it.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 23 of 30, by AaronS
vvbee wrote on Yesterday, 17:35:
I suppose only losing Physx under Vista/7. My current daily driver is a AMD and I noticed it does play better with older DX8/9 games in Windows 11 compared to my previous build with an Nvidia. But ideally I wanted something that was able to run earlier OS and avoid problems introduced by modern OS more than anything, plus its nice to have actual hardware rather than relying on emulation or patches. Part of the reason I went with a Phenom II / K-10 over a AM3+ CPU was because of cpuspd being able to slow it down considerably using P-states, this will be really good for those speed sensitive 98 games. CpuSpd - A Hardware Based CPU Speed Control Utility for DOS/Win9X Retro Gaming
I don't expect to be able to play everything but it should cover a hell of a lot with the ability to run nGlide and having access to the earlier 45.23 nvidia drivers, without having to pay insane prices for a voodoo card.
AlexZ wrote on Yesterday, 17:50:
Phenom II X6 1100T will not benefit from GTX 980. I had one and it got replaced by Vishera in AM3+ board. Vishera FX-8370 is abo […]
Thanks, this is sort of what I expected. I don't really intend to run games beyond 1600x1200 or 1920x1080 @ 60Hz, and yeah like I said I didn't really intend to use a AM3+ CPU but I got this MB really cheap and it was confirmed working with 98SE (XP and onwards are already confirmed in the specs), so it ticks the boxes for older OS as well. The only thing I was maybe curious about was if certain games would benefit from a faster GPU if they are well optimized and don't rely heavily on CPU but probably not. Physx is the only other thing I was curious about, I'm not sure if the GPU or memory clock speeds have an impact on the Physx capabilities or its a separate thing on the GPU (I know in the earlier days when it was Ageia you had to buy a separate card to handle it) but it might have an easier time rendering that stuff on the faster/later cards.
Reply 24 of 30, by AlexZ
Windows 98 games typically use DirectX 6 or 7 and will require compatibility patches.
You will not be able to play Windows Vista/7 era games with Physics on Phenom II X6 1100T comfortably. The performance drop I observed on Phenom II X4 955 was too much, Phenom II X6 1100T will have the same problem.
Vishera can have compatibility problems with Windows XP/Vista games, such as Crysis where a patch is needed otherwise it crashes due to lack of 3d now.
The main downside of Phenom II X6 1100T is very high power draw (6 cores) but insufficient performance for late games. See https://www.tomshardware.com/reviews/phenom-i … amd,2810-9.html how much it draws power (total system power draw). It's about 250W in total. Phenom II X4 970 consumes 208W. Phenom II X4 955 could be at 190W. OCing it could destroy the board.
Reply 25 of 30, by AaronS
AaronS wrote on Yesterday, 15:32:
Even for Physx games released around 2007/8?
Reply 26 of 30, by agent_x007
If you want to cover speed sensitive games, just make a DOS menu and add specific option with setmul utility set to disable L1/L2/L3 cache.
Dropping frequency is good, but disabling cache is better.
Playing 2008-2009 heavy PhysX games is going to be a pain on DX10 class hardware, mid range and better Fermi/Kepler should do just fine though.
Alternatively just add PhysX capable NV card.
Reply 27 of 30, by RetroBus
I had in issue when playing the game Mirrors Edge, it was all fine till at one point when the NPC's shoot glass, and the whole game went crazy would drop to 1 frame every 4 seconds. Couldn't figure it out till i read on some forum to disable PhysX
Reply 28 of 30, by AaronS
Yeah Mirrors Edge uses it for flags and glass https://www.youtube.com/watch?v=uFio7wMTQ2k
I did recently play this game again on my current AMD system (as well as Batman Arkham) and its a shame to miss out on these cool effects.
agent_x007 wrote on Yesterday, 22:07:
If you want to cover speed sensitive games, just make a DOS menu and add specific option with setmul utility set to disable L1/L […]
Alright, I think just incase I ever "upgrade" to a intel 3rd/4th gen system or this Phenom II build doesn't work out, I'll go with a 970 or 980, they're all more or less priced the same. It's really too bad there's no speed/cache control on the intel core ix, they would tick every box at that point.
Reply 29 of 30, by vvbee
AaronS wrote on Yesterday, 18:19:
Not a downside of the GTX 1070. Obvious downsides are multiple monitor cables, primary display competition etc., but that seems to be about it, other than the drivers in Vista not being official. In my view the 1070 has too much overlap with modern systems but that's not what you can't say about the 980 Ti either. This way it's at least balanced out toward Windows 7 while something more compatible does XP. I don't expect you to build this, just taking the chance to flesh out a better alternative to the common 980 + XP build.
Reply 30 of 30, by AaronS
vvbee wrote on Today, 07:28:
Yeah I understand. It makes more sense. I suppose it makes sense also to skip Vista and use 7 with some even more recent (definitely not on this board/CPU combo though), I'm not sure if there's anything that specifically prefers Vista over 7, otherwise for that I believe RTX 3xxx series is the limit.
