Reply 20 of 21, by Jo22
- l33t++
Re: DOS/UMBs: General Tips for Getting More Memory?
Helix applications work different to QEMM/EMM386 etc.
Instead of cramping everything into UMBs, Netroom for example will use a DOS VM to off-load heavy stuff like network software.
Or they may use pointers to point past 1 MB barrier (like Helix Multimedia Cloaking etc does).:
Here, small 1 KB stubs below 1 MB are working like a remote control to control the large, cloaking-enabled software running above 1 MB.
In simple words, I mean. I'm bad at wording, I'm afraid.
Anyway, those alternative ways of running memory heavy things may not cause the usual problems like QEMM/EMM386/386Max do.
So they're worth a try.
The Helix solutions also provide a DPMI host, which can be used if wished.
Using the DPMI host of QEMM instead is also a possibility.
Edited.
