Reply 20 of 22, by bracecomputerlab
Glad to hear that.
Guy wrote on 2025-10-09, 07:26:bracecomputerlab wrote on 2025-10-09, 05:21:I will say that VIA Technologies PT800 chipset is comparable to Intel 848P chipset. Both support 800 MT / s (200 MHz Quad Data R […]
Both support 800 MT / s (200 MHz Quad Data Rate or QDR) and DDR400 DDR SDRAM.
Personally, I will not say that VIA chipset around 2003 / 2004 time frame to be bad.
Generally speaking, Intel chipset tends to perform a few percent better on benchmarks compared to VIA / SiS chipsets, assuming similar configuration, but the difference is often so small that you may not notice it without benchmarking.
By 2003 or so, AGP related compatibility issues have been resolved.
At this point, whatever retro piece of equipment you can get a hold of is valuable.
I will not toss the mainboard unless it is completely broken (i.e., cracked PCB, smoked out PCB copper trace, etc.).Guy wrote on 2025-10-07, 14:36:I have a P4 system, it came with a MSI PT8 Neo-V mobo:
https://theretroweb.com/motherboards/s/msi-pt8-neo-vIs the pt800 a good and stable chipset, or should I switch to an Intel one, I have both 865 and 875 motherboards.
I'm definitely not throwing it out, it's good to have multiple working back ups:)
