How to find out if a program or path is missing something
Reply 20 of 93, by DustyShinigami
bakemono wrote on 2025-10-29, 08:43:
maybe check the registry to see what it's trying to run at startup time. software/microsoft/windows/currentversion/run (or something like that)
These are what load on startup, according to regedit, and what I have disabled:
The attachment IMG_5050.jpeg is no longer available
The attachment IMG_5051.jpeg is no longer available
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 21 of 93, by DustyShinigami
asdf53 wrote on 2025-10-29, 09:08:
Download FileMon 7.04, open the filter dialog. […]
You have two options: You can either enter the file name (xit) into the filter, FileMon will then tell you which program is trying to access that file at any moment. One problem is that if you don't know the file path, only the name, you have to work with wildcards (*xit*) and you'll probably get tons of unrelated results.
Or, enter a program name that you suspect, then see which files it's trying to access at launch. FileMon will then log the program activity and show you everything it's trying to access.
Yep, that's a great idea. If you're getting the error at boot, it's most likely a program that's being run from the Autorun key. For example, if "C:\creative\mixer.exe" (just an example) is in that list, you would add "c:\creative\mixer.exe" to the FileMon filter, then launch mixer.exe manually and see what happens.
And related to that, try disabling the HPT controller in the BIOS and hook up your drives to the first controller. There are so many reports online on that controller being buggy and corrupting other devices on the PCI bus. If you rule that out first, it might save you a lot of time troubleshooting.
Just tried FileMon and when selecting Find and searching for ‘xit’ just gives me no results found straight away. With Filter I just get a blank screen, so it can’t find anything with that word.
I’ll have to try enabling every startup item and see if it repeats the error and records anything.
OS: Windows 98 SE
Reply 22 of 93, by wierd_w
I'd like an image of the 'Xit not found' error message, if possible.
Reply 23 of 93, by DustyShinigami
wierd_w wrote on 2025-10-29, 17:37:
Sure thing. It’s just getting it to do it. 😅 When I don’t want it, it happens. And then when I do - nothing. As I said before, if I don’t get that error, I’ll get the SB audio cut the startup sound off and then I get no sound until I switch the between the cards/audio device.
I suspect there must be a bug with the drivers I managed to find/get working, but I’ve no idea if there’s a patch.
OS: Windows 98 SE
Reply 24 of 93, by DustyShinigami
Also, I noticed in FileMon that it was unable to find/load Rundll32…? And then just now got this:
The attachment IMG_5056.jpeg is no longer available
OS: Windows 98 SE
Reply 25 of 93, by wierd_w
Rundll32 is a system process for executing procedure calls contained inside .dll files.
THIS is the kind of thing that dependency walker is for, if you can trigger the exception.
This is one of those 'basically useless and unhelpful' error messages windows loves to deliver.
All it says is
'hey, some executable dll procedure made rundll32 real mad. Which one? Who cares. Which procedure call? Why do you want to know!? I quit!'
Which is not very useful, but microsoft sure seems to think it is.
Dependency walker will tell you the things you really want to know.
Reply 26 of 93, by DustyShinigami
I kind of became a bit distracted with another problem. An old favourite game of mine won't install for some weird reason, so I'm trying to figure out what's been installed or done that's preventing it from working. So I had to make an image/backup of the drive so I can remove stuff to find the cause. It wasn't the sound card's drivers anyway, which I uninstalled. I've re-installed them from scratch, so I'll see if that error pops up again.
OS: Windows 98 SE
Reply 27 of 93, by DustyShinigami
Ha. Okay, I did a fresh install of Windows for the benefit of troubleshooting this game. All I've installed are the USB drivers, enabled the boot menu, and copied/pasted Ghost. I then created my first image, loaded back into Windows, aaaaaand... greeted with the same error message. 🤣
The attachment IMG_5061.JPG is no longer available
So it's clearly not related to my audio drivers. So possibly Ghost or the USB drivers...?
EDIT: Hmm. It's done something it hasn't done before anyway. It's automatically installed some Yamaha audio drivers for my ISA sound card. WDM ones, which I don't want. So maybe that's causing it...?
OS: Windows 98 SE
Reply 28 of 93, by DustyShinigami
Not having any luck with this so far. I can’t seem to pinpoint where/what it’s related to and I’m not seeing any clues in FileMon. I expect Dependency Walker will only be of use if I knew exactly what file it was linked to…? 😕
OS: Windows 98 SE
Reply 29 of 93, by asdf53
DustyShinigami wrote on 2025-10-31, 19:34:
Can you describe step by step what you're doing?
I just tested it, entered "xit" as the FileMon include filter and then ran "xit" - using Start Menu > Run, and programmatically using ShellExecuteEx, which is probably what the offending program is doing. I'm getting the same error popup "Cannot find the file 'xit' (or one of its components)..." and a list of entries appear in the FileMon window that show which program triggered the access.
You obviously have to run the actual program that will trigger the access - so go through the Start Menu's autorun entries and also the registry entries and run each of these programs/commands manually once FileMon is running.
Reply 30 of 93, by DustyShinigami
asdf53 wrote on 2025-11-01, 09:44:
Can you describe step by step what you're doing? […]
I see. Usually when I load FileMon, it’s after the error comes up, but it doesn’t seem to register it and only adds entries from the moment it’s loaded, but never anything from before.
So I need to run ShellExecuteEx? Or type ShellExecuteEx xit?
I’ll also do a search in regedit for anything called xit. See what turns up there, if anything. Thanks.
OS: Windows 98 SE
Reply 31 of 93, by asdf53
DustyShinigami wrote on 2025-11-01, 11:47:
I see. Usually when I load FileMon, it’s after the error comes up, but it doesn’t seem to register it and only adds entries from […]
That's to be expected, this is why you have to manually trigger the error after loading FileMon. Since your error appears at boot, it's likely triggered by one of the autorun programs, either in the start menu or in the registry.
Example: You have "C:\creative\mixer.exe" under "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run". You would then copy the mixer.exe command from the registry and run it with Start menu>run while FileMon is running. Repeat for all remaining entries until the error appears.
ShellExecuteEx isn't a program, it's a Win32 API call that a program uses internally to run another program. This causes the actual "file not found" popup that you're getting.
Reply 32 of 93, by DustyShinigami
asdf53 wrote on 2025-11-01, 12:10:
That's to be expected, this is why you have to manually trigger the error after loading FileMon. Since your error appears at boo […]
Right. Gotcha. I’ll do some digging over the weekend if it pops up again. I’m sure it will. Thanks.
OS: Windows 98 SE
Reply 33 of 93, by asdf53
Here's another thing you can try:
Run FileMon, open the filter dialog, enter "xit", press OK, close FileMon. Open FileMon again to verify that it remembered the filter setting (it does by default). Then:
Run regedit, go to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunServices, and add a new string value (name doesn't matter), then right click it and "change", enter "c:\filemon\filemon.exe -q" or whatever its located at. "-q" means no user prompt at launch. Reboot.
In theory, this should run FileMon as early as possible in the boot process, so if it loads fast enough, it'll already be listening when the program that causes the error starts.
Reply 34 of 93, by DustyShinigami
asdf53 wrote on 2025-11-01, 15:14:
Here's another thing you can try: […]
Awesome. Thanks for the tip. 😁 I'll give that a go now.
OS: Windows 98 SE
Reply 35 of 93, by DustyShinigami
Yeah, when I want it to come up with the error, it suddenly becomes too shy. 🤣
OS: Windows 98 SE
Reply 36 of 93, by DustyShinigami
Well, since setting FileMon to load instantly, the xit error hasn't popped up once. However, on some occasions, if I have my Sound Blaster enabled as the primary audio device, it can sometimes cut out during the log on audio at startup. And then I have no sound. I have to toggle back between my ISA and the PCI cards to get it back. I did save the FileMon logs before and after, but both look pretty identical to me. The same things that didn't load didn't load even when the audio plays and works correctly, so they can't be the cause. I've not been able to see anything majorly different, but maybe someone else can...?
Here's the log for all things Sound Blaster related when the audio was working fine:
0 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB.PIF NOTFOUND GetAttributes 1 17:47:23 Explorer:FFE0D747 At […]
1 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB.COM NOTFOUND GetAttributes
2 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB.EXE NOTFOUND GetAttributes
3 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB.BAT NOTFOUND GetAttributes
4 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB.LNK NOTFOUND GetAttributes
5 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB.CMD NOTFOUND GetAttributes
6 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB NOTFOUND GetAttributes
7 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.PIF NOTFOUND GetAttributes
8 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.COM NOTFOUND GetAttributes
9 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.EXE NOTFOUND GetAttributes
10 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.BAT NOTFOUND GetAttributes
11 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.LNK NOTFOUND GetAttributes
12 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.CMD NOTFOUND GetAttributes
13 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE NOTFOUND GetAttributes
14 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
15 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
16 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
17 17:47:23 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
18 17:47:23 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
19 17:47:23 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS SB Drive Det
20 17:47:23 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS
21 17:47:23 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS SBDrvDet.exe
22 17:47:23 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS
23 17:47:23 Explorer:FFE0D747 Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS OPENEXISTING READONLY DENYNONE
24 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Get Access
25 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Set Access
26 17:47:23 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 64
27 17:47:23 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
28 17:47:23 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 64
29 17:47:23 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 320 / New offset: 320
30 17:47:23 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 320 Length: 4
31 17:47:23 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 340 / New offset: 340
32 17:47:23 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 340 Length: 4
33 17:47:23 Explorer:FFE0D747 Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS CLOSE_FINAL
34 17:47:23 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
35 17:47:23 Explorer:FFE0D747 Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
36 17:47:23 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 64
37 17:47:23 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
38 17:47:23 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 248
39 17:47:23 Explorer:FFE0D747 Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS CLOSE_FINAL
40 17:47:23 ???:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
41 17:47:23 ???:FFE11DA7 Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS QUERY
42 17:47:23 ???:FFE11DA7 Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
43 17:47:23 ???:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 64
44 17:47:23 ???:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
45 17:47:23 ???:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 248
46 17:47:23 ???:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
47 17:47:23 ???:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 408
48 17:47:23 ???:FFE11DA7 Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS QUERY
49 17:47:23 ???:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 20480 Length: 4096
50 17:47:23 ???:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\MFC42.DLL NOTFOUND GetAttributes
51 17:47:23 ???:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 12288 Length: 4096
52 17:47:23 Sbdrvdet:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE.LOCAL NOTFOUND GetAttributes
53 17:47:23 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 4096
54 17:47:24 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 16384 Length: 512
55 17:47:24 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
56 17:47:24 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
57 17:47:24 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
58 17:47:24 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
59 17:47:24 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
60 17:47:24 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS SBAudigy2
61 17:47:24 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS
62 17:47:24 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS DVDAudio
63 17:47:24 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS
64 17:47:24 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
65 17:47:24 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
66 17:47:24 Explorer:FFE0D747 Open C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS OPENEXISTING READONLY DENYNONE
67 17:47:24 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Get Access
68 17:47:24 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Set Access
69 17:47:24 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 64
70 17:47:24 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
71 17:47:24 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 64
72 17:47:24 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 320 / New offset: 320
73 17:47:24 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 320 Length: 4
74 17:47:24 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 340 / New offset: 340
75 17:47:24 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 340 Length: 4
76 17:47:24 Explorer:FFE0D747 Close C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CLOSE_FINAL
77 17:47:24 Explorer:FFE0D747 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
78 17:47:24 Explorer:FFE0D747 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
79 17:47:24 Explorer:FFE0D747 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
80 17:47:24 Explorer:FFE0D747 Open C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
81 17:47:24 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 64
82 17:47:24 Explorer:FFE0D747 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
83 17:47:24 Explorer:FFE0D747 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 248
84 17:47:24 Explorer:FFE0D747 Close C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CLOSE_FINAL
85 17:47:25 ???:FFE1FD7F Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
86 17:47:25 ???:FFE1FD7F Directory C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS QUERY
87 17:47:25 ???:FFE1FD7F Open C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
88 17:47:25 ???:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 64
89 17:47:25 ???:FFE1FD7F Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
90 17:47:25 ???:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 248
91 17:47:25 ???:FFE1FD7F Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
92 17:47:25 ???:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 408
93 17:47:25 ???:FFE1FD7F Directory C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS QUERY
94 17:47:25 ???:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 20480 Length: 4096
95 17:47:25 ???:FFE1FD7F Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\MFC42.DLL NOTFOUND GetAttributes
96 17:47:25 ???:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 12288 Length: 4096
97 17:47:25 Ctdvddet:FFE1FD7F Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE.LOCAL NOTFOUND GetAttributes
98 17:47:25 Sbdrvdet:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS GetAttributes
99 17:47:25 Sbdrvdet:FFE11DA7 Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS QUERY
100 17:47:25 Sbdrvdet:FFE11DA7 Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS OPENEXISTING READONLY DENYWRITE
101 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Offset: 0 Length: 64
102 17:47:25 Sbdrvdet:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Beginning Offset: 176 / New offset: 176
103 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Offset: 176 Length: 248
104 17:47:25 Sbdrvdet:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Beginning Offset: 176 / New offset: 176
105 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Offset: 176 Length: 328
106 17:47:25 Sbdrvdet:FFE11DA7 Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS QUERY
107 17:47:25 Ctdvddet:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 4096
108 17:47:25 Sbdrvdet:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS GetAttributes
109 17:47:25 Sbdrvdet:FFE11DA7 Directory C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS QUERY
110 17:47:25 Sbdrvdet:FFE11DA7 Open C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS OPENEXISTING READONLY DENYWRITE
111 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 0 Length: 64
112 17:47:25 Sbdrvdet:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Beginning Offset: 240 / New offset: 240
113 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 240 Length: 248
114 17:47:25 Sbdrvdet:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Beginning Offset: 240 / New offset: 240
115 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 240 Length: 448
116 17:47:25 Sbdrvdet:FFE11DA7 Directory C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS QUERY
117 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 86016 Length: 1536
118 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 69632 Length: 4096
119 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 73728 Length: 4096
120 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 81920 Length: 4096
121 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 77824 Length: 4096
122 17:47:25 Sbdrvdet:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS GetAttributes
123 17:47:25 Sbdrvdet:FFE11DA7 Open C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS OPENEXISTING READONLY COMPATIBILITY
124 17:47:25 Sbdrvdet:FFE11DA7 Attributes C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Get Modify
125 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 0 Length: 64
126 17:47:25 Sbdrvdet:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Beginning Offset: 128 / New offset: 128
127 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 128 Length: 64
128 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 192 Length: 212
129 17:47:25 Sbdrvdet:FFE11DA7 Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Beginning Offset: 448 / New offset: 448
130 17:47:25 Sbdrvdet:FFE11DA7 Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 448 Length: 4544
131 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
132 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
133 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS SB Drive Det
134 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS
135 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS SBDrvDet.crl
136 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS
137 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
138 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
139 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS SB Drive Det
140 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS
141 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS SBDrvDet.crl
142 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS
143 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
144 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
145 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS SBAudigy2
146 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS
147 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS DVDAudio
148 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS
149 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
150 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
151 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
152 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
153 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS SBAudigy2
154 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS
155 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS DVDAudio
156 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS
157 17:47:26 Filemon:FFE06937 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
158 17:47:26 Filemon:FFE06937 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
159 17:47:26 Ctdvddet:FFE1FD7F Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 16384 Length: 1024
160 17:47:28 Sbdrvdet:FFE11DA7 Close C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS CLOSE_FINAL
161 17:47:28 Sbdrvdet:FFE11DA7 Close C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS CLOSE_FINAL
162 17:47:28 Sbdrvdet:FFE11DA7 Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS CLOSE_FINAL
163 17:47:28 KERNEL32:FFEF825B Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS CLOSE_FINAL
164 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\*.* SUCCESS Creative
165 17:47:29 Explorer:FFE0D747 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS .
166 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS ..
167 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS Sound Blaster Audigy 2
168 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS Audio Stream Recorder 2
169 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS Technical Support.lnk
170 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS OPENEXISTING READONLY DENYNONE
171 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS Offset: 0 Length: 4096
172 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS CLOSE_FINAL
173 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS OPENEXISTING READONLY DENYNONE
174 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS Offset: 0 Length: 4096
175 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS CLOSE_FINAL
176 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* NOMORE
177 17:47:29 Explorer:FFE0D747 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS
178 17:47:29 Explorer:FFE0D747 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS .
179 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS ..
180 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative MiniDisc Center.lnk
181 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
182 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS Offset: 0 Length: 4096
183 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS CLOSE_FINAL
184 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
185 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS Offset: 0 Length: 4096
186 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS CLOSE_FINAL
187 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Diagnostics.lnk
188 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
189 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS Offset: 0 Length: 4096
190 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS CLOSE_FINAL
191 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
192 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS Offset: 0 Length: 4096
193 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS CLOSE_FINAL
194 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative WaveStudio.lnk
195 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
196 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS Offset: 0 Length: 4096
197 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS CLOSE_FINAL
198 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
199 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS Offset: 0 Length: 4096
200 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS CLOSE_FINAL
201 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS SoundFont Bank Manager.lnk
202 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
203 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS Offset: 0 Length: 4096
204 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS CLOSE_FINAL
205 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
206 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS Offset: 0 Length: 4096
207 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS CLOSE_FINAL
208 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Speaker Calibrator.lnk
209 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS OPENEXISTING READONLY DENYNONE
210 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS Offset: 0 Length: 4096
211 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS CLOSE_FINAL
212 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS OPENEXISTING READONLY DENYNONE
213 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS Offset: 0 Length: 4096
214 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS CLOSE_FINAL
215 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS EAX Console.lnk
216 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
217 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS Offset: 0 Length: 4096
218 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS CLOSE_FINAL
219 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
220 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS Offset: 0 Length: 4096
221 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS CLOSE_FINAL
222 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Surround Mixer.lnk
223 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
224 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS Offset: 0 Length: 4096
225 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS CLOSE_FINAL
226 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
227 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS Offset: 0 Length: 4096
228 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS CLOSE_FINAL
229 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Speaker Settings.lnk
230 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
231 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS Offset: 0 Length: 4096
232 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS CLOSE_FINAL
233 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
234 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS Offset: 0 Length: 4096
235 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS CLOSE_FINAL
236 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Getting Started Demo.lnk
237 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
238 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS Offset: 0 Length: 4096
239 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS CLOSE_FINAL
240 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
241 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS Offset: 0 Length: 4096
242 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS CLOSE_FINAL
243 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Restore Defaults.lnk
244 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
245 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS Offset: 0 Length: 4096
246 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS CLOSE_FINAL
247 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
248 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS Offset: 0 Length: 4096
249 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS CLOSE_FINAL
250 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative AudioHQ.lnk
251 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS OPENEXISTING READONLY DENYNONE
252 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS Offset: 0 Length: 4096
253 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS CLOSE_FINAL
254 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS OPENEXISTING READONLY DENYNONE
255 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS Offset: 0 Length: 4096
256 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS CLOSE_FINAL
257 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS MediaSource DVD-Audio Player.lnk
258 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
259 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS Offset: 0 Length: 4096
260 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS CLOSE_FINAL
261 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
262 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS Offset: 0 Length: 4096
263 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS CLOSE_FINAL
264 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Documentation
265 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Utility
266 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Welcome Menu.lnk
267 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS OPENEXISTING READONLY DENYNONE
268 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS Offset: 0 Length: 4096
269 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS CLOSE_FINAL
270 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS OPENEXISTING READONLY DENYNONE
271 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS Offset: 0 Length: 4096
272 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS CLOSE_FINAL
273 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* NOMORE
274 17:47:29 Explorer:FFE0D747 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS
275 17:47:29 Explorer:FFE0D747 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS .
276 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS ..
277 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS Audio Stream Recorder.lnk
278 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
279 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS Offset: 0 Length: 4096
280 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS CLOSE_FINAL
281 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
282 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS Offset: 0 Length: 4096
283 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS CLOSE_FINAL
284 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS Audio Stream Recorder Help.lnk
285 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS OPENEXISTING READONLY DENYNONE
286 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS Offset: 0 Length: 4096
287 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS CLOSE_FINAL
288 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS OPENEXISTING READONLY DENYNONE
289 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS Offset: 0 Length: 4096
290 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS CLOSE_FINAL
291 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS Readme.lnk
292 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS OPENEXISTING READONLY DENYNONE
293 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS Offset: 0 Length: 4096
294 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS CLOSE_FINAL
295 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS OPENEXISTING READONLY DENYNONE
296 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS Offset: 0 Length: 4096
297 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS CLOSE_FINAL
298 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* NOMORE
299 17:47:29 Explorer:FFE0D747 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS
300 17:47:29 Explorer:FFE0D747 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS .
301 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS ..
302 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS Online Manual.lnk
303 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS OPENEXISTING READONLY DENYNONE
304 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS Offset: 0 Length: 4096
305 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS CLOSE_FINAL
306 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS OPENEXISTING READONLY DENYNONE
307 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS Offset: 0 Length: 4096
308 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS CLOSE_FINAL
309 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS Music Creation Guide.lnk
310 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
311 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS Offset: 0 Length: 4096
312 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS CLOSE_FINAL
313 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
314 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS Offset: 0 Length: 4096
315 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS CLOSE_FINAL
316 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* NOMORE
317 17:47:29 Explorer:FFE0D747 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS
318 17:47:29 Explorer:FFE0D747 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS .
319 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS ..
320 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS Driver Utility Program.lnk
321 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS OPENEXISTING READONLY DENYNONE
322 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS Offset: 0 Length: 4096
323 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS CLOSE_FINAL
324 17:47:29 Explorer:FFE0D747 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS OPENEXISTING READONLY DENYNONE
325 17:47:29 Explorer:FFE0D747 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS Offset: 0 Length: 4096
326 17:47:29 Explorer:FFE0D747 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS CLOSE_FINAL
327 17:47:29 Explorer:FFE0D747 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* NOMORE
328 17:47:29 Explorer:FFE0D747 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS
And then after the audio cut out and stopped working:
0 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB.PIF NOTFOUND GetAttributes 1 18:20:49 Explorer:FFE0D527 At […]
1 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB.COM NOTFOUND GetAttributes
2 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB.EXE NOTFOUND GetAttributes
3 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB.BAT NOTFOUND GetAttributes
4 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB.LNK NOTFOUND GetAttributes
5 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB.CMD NOTFOUND GetAttributes
6 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB NOTFOUND GetAttributes
7 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.PIF NOTFOUND GetAttributes
8 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.COM NOTFOUND GetAttributes
9 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.EXE NOTFOUND GetAttributes
10 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.BAT NOTFOUND GetAttributes
11 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.LNK NOTFOUND GetAttributes
12 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE.CMD NOTFOUND GetAttributes
13 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE NOTFOUND GetAttributes
14 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
15 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
16 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
17 18:20:49 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
18 18:20:49 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
19 18:20:49 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS SB Drive Det
20 18:20:49 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS
21 18:20:49 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS SBDrvDet.exe
22 18:20:49 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS
23 18:20:49 Explorer:FFE0D527 Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS OPENEXISTING READONLY DENYNONE
24 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Get Access
25 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Set Access
26 18:20:49 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 64
27 18:20:49 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
28 18:20:49 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 64
29 18:20:49 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 320 / New offset: 320
30 18:20:49 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 320 Length: 4
31 18:20:49 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 340 / New offset: 340
32 18:20:49 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 340 Length: 4
33 18:20:49 Explorer:FFE0D527 Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS CLOSE_FINAL
34 18:20:49 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
35 18:20:49 Explorer:FFE0D527 Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
36 18:20:49 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 64
37 18:20:49 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
38 18:20:49 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 248
39 18:20:49 Explorer:FFE0D527 Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS CLOSE_FINAL
40 18:20:49 ???:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS GetAttributes
41 18:20:49 ???:FFE16E9B Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS QUERY
42 18:20:49 ???:FFE16E9B Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
43 18:20:49 ???:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 64
44 18:20:49 ???:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
45 18:20:49 ???:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 248
46 18:20:49 ???:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
47 18:20:49 ???:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 248 Length: 408
48 18:20:49 ???:FFE16E9B Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS QUERY
49 18:20:49 ???:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 20480 Length: 4096
50 18:20:49 ???:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\MFC42.DLL NOTFOUND GetAttributes
51 18:20:50 ???:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 12288 Length: 4096
52 18:20:50 Sbdrvdet:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE.LOCAL NOTFOUND GetAttributes
53 18:20:50 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 0 Length: 4096
54 18:20:50 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
55 18:20:50 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
56 18:20:50 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
57 18:20:50 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
58 18:20:50 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
59 18:20:50 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS SBAudigy2
60 18:20:50 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS
61 18:20:50 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS DVDAudio
62 18:20:50 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS
63 18:20:50 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
64 18:20:50 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
65 18:20:50 Explorer:FFE0D527 Open C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS OPENEXISTING READONLY DENYNONE
66 18:20:50 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Get Access
67 18:20:50 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Set Access
68 18:20:50 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 64
69 18:20:50 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
70 18:20:50 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 64
71 18:20:50 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 320 / New offset: 320
72 18:20:50 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 320 Length: 4
73 18:20:50 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 340 / New offset: 340
74 18:20:50 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 340 Length: 4
75 18:20:50 Explorer:FFE0D527 Close C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CLOSE_FINAL
76 18:20:50 Explorer:FFE0D527 FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
77 18:20:50 Explorer:FFE0D527 FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
78 18:20:50 Explorer:FFE0D527 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
79 18:20:50 Explorer:FFE0D527 Open C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
80 18:20:50 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 64
81 18:20:50 Explorer:FFE0D527 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
82 18:20:50 Explorer:FFE0D527 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 248
83 18:20:50 Explorer:FFE0D527 Close C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CLOSE_FINAL
84 18:20:50 ???:FFE1FB33 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS GetAttributes
85 18:20:50 ???:FFE1FB33 Directory C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS QUERY
86 18:20:50 ???:FFE1FB33 Open C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS OPENEXISTING READONLY DENYWRITE
87 18:20:50 ???:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 64
88 18:20:50 ???:FFE1FB33 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
89 18:20:50 ???:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 248
90 18:20:50 ???:FFE1FB33 Seek C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Beginning Offset: 248 / New offset: 248
91 18:20:50 ???:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 248 Length: 408
92 18:20:50 ???:FFE1FB33 Directory C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS QUERY
93 18:20:50 ???:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 20480 Length: 4096
94 18:20:50 ???:FFE1FB33 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\MFC42.DLL NOTFOUND GetAttributes
95 18:20:50 ???:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 12288 Length: 4096
96 18:20:50 Ctdvddet:FFE1FB33 Attributes C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE.LOCAL NOTFOUND GetAttributes
97 18:20:51 Ctdvddet:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 0 Length: 4096
98 18:20:51 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS Offset: 16384 Length: 512
99 18:20:51 Sbdrvdet:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS GetAttributes
100 18:20:51 Sbdrvdet:FFE16E9B Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS QUERY
101 18:20:51 Sbdrvdet:FFE16E9B Open C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS OPENEXISTING READONLY DENYWRITE
102 18:20:51 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Offset: 0 Length: 64
103 18:20:51 Sbdrvdet:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Beginning Offset: 176 / New offset: 176
104 18:20:51 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Offset: 176 Length: 248
105 18:20:51 Sbdrvdet:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Beginning Offset: 176 / New offset: 176
106 18:20:51 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS Offset: 176 Length: 328
107 18:20:51 Sbdrvdet:FFE16E9B Directory C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS QUERY
108 18:20:51 Ctdvddet:FFE1FB33 Read C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS Offset: 16384 Length: 1024
109 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
110 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
111 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS SB Drive Det
112 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS
113 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS SBDrvDet.crl
114 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS
115 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
116 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
117 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS SB Drive Det
118 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET SUCCESS
119 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS SBDrvDet.crl
120 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS
121 18:20:52 Sbdrvdet:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS GetAttributes
122 18:20:52 Sbdrvdet:FFE16E9B Directory C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS QUERY
123 18:20:52 Sbdrvdet:FFE16E9B Open C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS OPENEXISTING READONLY DENYWRITE
124 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 0 Length: 64
125 18:20:52 Sbdrvdet:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Beginning Offset: 240 / New offset: 240
126 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 240 Length: 248
127 18:20:52 Sbdrvdet:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Beginning Offset: 240 / New offset: 240
128 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 240 Length: 448
129 18:20:52 Sbdrvdet:FFE16E9B Directory C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS QUERY
130 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 86016 Length: 1536
131 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 69632 Length: 4096
132 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 73728 Length: 4096
133 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
134 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
135 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS SBAudigy2
136 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS
137 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS DVDAudio
138 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS
139 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
140 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
141 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE SUCCESS Creative
142 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE SUCCESS
143 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS SBAudigy2
144 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2 SUCCESS
145 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS DVDAudio
146 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO SUCCESS
147 18:20:52 Filemon:FFE06E0F FindOpen C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS CTDVDDET.exe
148 18:20:52 Filemon:FFE06E0F FindClose C:\PROGRAM FILES\CREATIVE\SBAUDIGY2\DVDAUDIO\CTDVDDET.EXE SUCCESS
149 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 81920 Length: 4096
150 18:20:52 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS Offset: 77824 Length: 4096
151 18:20:53 Sbdrvdet:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS GetAttributes
152 18:20:53 Sbdrvdet:FFE16E9B Open C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS OPENEXISTING READONLY COMPATIBILITY
153 18:20:53 Sbdrvdet:FFE16E9B Attributes C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Get Modify
154 18:20:53 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 0 Length: 64
155 18:20:53 Sbdrvdet:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Beginning Offset: 128 / New offset: 128
156 18:20:53 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 128 Length: 64
157 18:20:53 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 192 Length: 212
158 18:20:53 Sbdrvdet:FFE16E9B Seek C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Beginning Offset: 448 / New offset: 448
159 18:20:53 Sbdrvdet:FFE16E9B Read C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS Offset: 448 Length: 4544
160 18:20:55 Sbdrvdet:FFE16E9B Close C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD16.DLL SUCCESS CLOSE_FINAL
161 18:20:55 Sbdrvdet:FFE16E9B Close C:\PROGRAM FILES\CREATIVE\SHAREDLL\PFMOD.DLL SUCCESS CLOSE_FINAL
162 18:20:55 Sbdrvdet:FFE16E9B Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.CRL SUCCESS CLOSE_FINAL
163 18:20:55 KERNEL32:FFEF8563 Close C:\PROGRAM FILES\CREATIVE\SB DRIVE DET\SBDRVDET.EXE SUCCESS CLOSE_FINAL
164 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\*.* SUCCESS Creative
165 18:20:56 Explorer:FFE0D527 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS .
166 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS ..
167 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS Sound Blaster Audigy 2
168 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS Audio Stream Recorder 2
169 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS Technical Support.lnk
170 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS OPENEXISTING READONLY DENYNONE
171 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS Offset: 0 Length: 4096
172 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS CLOSE_FINAL
173 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS OPENEXISTING READONLY DENYNONE
174 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS Offset: 0 Length: 4096
175 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\TECHNICAL SUPPORT.LNK SUCCESS CLOSE_FINAL
176 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* NOMORE
177 18:20:56 Explorer:FFE0D527 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\*.* SUCCESS
178 18:20:56 Explorer:FFE0D527 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS .
179 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS ..
180 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative MiniDisc Center.lnk
181 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
182 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS Offset: 0 Length: 4096
183 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS CLOSE_FINAL
184 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
185 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS Offset: 0 Length: 4096
186 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE MINIDISC CENTER.LNK SUCCESS CLOSE_FINAL
187 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Diagnostics.lnk
188 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
189 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS Offset: 0 Length: 4096
190 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS CLOSE_FINAL
191 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
192 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS Offset: 0 Length: 4096
193 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE DIAGNOSTICS.LNK SUCCESS CLOSE_FINAL
194 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative WaveStudio.lnk
195 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
196 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS Offset: 0 Length: 4096
197 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS CLOSE_FINAL
198 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
199 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS Offset: 0 Length: 4096
200 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE WAVESTUDIO.LNK SUCCESS CLOSE_FINAL
201 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS SoundFont Bank Manager.lnk
202 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
203 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS Offset: 0 Length: 4096
204 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS CLOSE_FINAL
205 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
206 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS Offset: 0 Length: 4096
207 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\SOUNDFONT BANK MANAGER.LNK SUCCESS CLOSE_FINAL
208 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Speaker Calibrator.lnk
209 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS OPENEXISTING READONLY DENYNONE
210 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS Offset: 0 Length: 4096
211 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS CLOSE_FINAL
212 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS OPENEXISTING READONLY DENYNONE
213 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS Offset: 0 Length: 4096
214 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER CALIBRATOR.LNK SUCCESS CLOSE_FINAL
215 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS EAX Console.lnk
216 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
217 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS Offset: 0 Length: 4096
218 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS CLOSE_FINAL
219 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
220 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS Offset: 0 Length: 4096
221 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\EAX CONSOLE.LNK SUCCESS CLOSE_FINAL
222 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Surround Mixer.lnk
223 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
224 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS Offset: 0 Length: 4096
225 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS CLOSE_FINAL
226 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
227 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS Offset: 0 Length: 4096
228 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SURROUND MIXER.LNK SUCCESS CLOSE_FINAL
229 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Speaker Settings.lnk
230 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
231 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS Offset: 0 Length: 4096
232 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS CLOSE_FINAL
233 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
234 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS Offset: 0 Length: 4096
235 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE SPEAKER SETTINGS.LNK SUCCESS CLOSE_FINAL
236 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Getting Started Demo.lnk
237 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
238 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS Offset: 0 Length: 4096
239 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS CLOSE_FINAL
240 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS OPENEXISTING READONLY DENYNONE
241 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS Offset: 0 Length: 4096
242 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\GETTING STARTED DEMO.LNK SUCCESS CLOSE_FINAL
243 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative Restore Defaults.lnk
244 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
245 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS Offset: 0 Length: 4096
246 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS CLOSE_FINAL
247 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS OPENEXISTING READONLY DENYNONE
248 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS Offset: 0 Length: 4096
249 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE RESTORE DEFAULTS.LNK SUCCESS CLOSE_FINAL
250 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Creative AudioHQ.lnk
251 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS OPENEXISTING READONLY DENYNONE
252 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS Offset: 0 Length: 4096
253 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS CLOSE_FINAL
254 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS OPENEXISTING READONLY DENYNONE
255 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS Offset: 0 Length: 4096
256 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\CREATIVE AUDIOHQ.LNK SUCCESS CLOSE_FINAL
257 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS MediaSource DVD-Audio Player.lnk
258 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
259 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS Offset: 0 Length: 4096
260 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS CLOSE_FINAL
261 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
262 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS Offset: 0 Length: 4096
263 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\MEDIASOURCE DVD-AUDIO PLAYER.LNK SUCCESS CLOSE_FINAL
264 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Documentation
265 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Utility
266 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS Welcome Menu.lnk
267 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS OPENEXISTING READONLY DENYNONE
268 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS Offset: 0 Length: 4096
269 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS CLOSE_FINAL
270 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS OPENEXISTING READONLY DENYNONE
271 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS Offset: 0 Length: 4096
272 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\WELCOME MENU.LNK SUCCESS CLOSE_FINAL
273 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* NOMORE
274 18:20:56 Explorer:FFE0D527 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\*.* SUCCESS
275 18:20:56 Explorer:FFE0D527 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS .
276 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS ..
277 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS Audio Stream Recorder.lnk
278 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
279 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS Offset: 0 Length: 4096
280 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS CLOSE_FINAL
281 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS OPENEXISTING READONLY DENYNONE
282 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS Offset: 0 Length: 4096
283 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER.LNK SUCCESS CLOSE_FINAL
284 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS Audio Stream Recorder Help.lnk
285 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS OPENEXISTING READONLY DENYNONE
286 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS Offset: 0 Length: 4096
287 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS CLOSE_FINAL
288 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS OPENEXISTING READONLY DENYNONE
289 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS Offset: 0 Length: 4096
290 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\AUDIO STREAM RECORDER HELP.LNK SUCCESS CLOSE_FINAL
291 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS Readme.lnk
292 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS OPENEXISTING READONLY DENYNONE
293 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS Offset: 0 Length: 4096
294 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS CLOSE_FINAL
295 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS OPENEXISTING READONLY DENYNONE
296 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS Offset: 0 Length: 4096
297 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\README.LNK SUCCESS CLOSE_FINAL
298 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* NOMORE
299 18:20:56 Explorer:FFE0D527 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\AUDIO STREAM RECORDER 2\*.* SUCCESS
300 18:20:56 Explorer:FFE0D527 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS .
301 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS ..
302 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS Online Manual.lnk
303 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS OPENEXISTING READONLY DENYNONE
304 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS Offset: 0 Length: 4096
305 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS CLOSE_FINAL
306 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS OPENEXISTING READONLY DENYNONE
307 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS Offset: 0 Length: 4096
308 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\ONLINE MANUAL.LNK SUCCESS CLOSE_FINAL
309 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS Music Creation Guide.lnk
310 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
311 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS Offset: 0 Length: 4096
312 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS CLOSE_FINAL
313 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS OPENEXISTING READONLY DENYNONE
314 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS Offset: 0 Length: 4096
315 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\MUSIC CREATION GUIDE.LNK SUCCESS CLOSE_FINAL
316 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* NOMORE
317 18:20:56 Explorer:FFE0D527 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\DOCUMENTATION\*.* SUCCESS
318 18:20:56 Explorer:FFE0D527 FindOpen C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS .
319 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS ..
320 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS Driver Utility Program.lnk
321 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS OPENEXISTING READONLY DENYNONE
322 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS Offset: 0 Length: 4096
323 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS CLOSE_FINAL
324 18:20:56 Explorer:FFE0D527 Open C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS OPENEXISTING READONLY DENYNONE
325 18:20:56 Explorer:FFE0D527 Read C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS Offset: 0 Length: 4096
326 18:20:56 Explorer:FFE0D527 Close C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\DRIVER UTILITY PROGRAM.LNK SUCCESS CLOSE_FINAL
327 18:20:56 Explorer:FFE0D527 FindNext C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* NOMORE
328 18:20:56 Explorer:FFE0D527 FindClose C:\WINDOWS\START MENU\PROGRAMS\CREATIVE\SOUND BLASTER AUDIGY 2\UTILITY\*.* SUCCESS
EDIT: Aaaaarrrgh. And when I don't have the 'xit' filter applied, because I still had it set to Sound Blaster, the error pops up. DX
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 37 of 93, by DustyShinigami
Success! Caught it. Though I'm still non plussed.
0 00:55:06 Explorer:FFFC292F Attributes C:\XIT.PIF NOTFOUND GetAttributes 1 00:55:06 Explorer:FFFC292F Attributes C:\XIT.COM NO […]
1 00:55:06 Explorer:FFFC292F Attributes C:\XIT.COM NOTFOUND GetAttributes
2 00:55:06 Explorer:FFFC292F Attributes C:\XIT.EXE NOTFOUND GetAttributes
3 00:55:06 Explorer:FFFC292F Attributes C:\XIT.BAT NOTFOUND GetAttributes
4 00:55:06 Explorer:FFFC292F Attributes C:\XIT.LNK NOTFOUND GetAttributes
5 00:55:06 Explorer:FFFC292F Attributes C:\XIT.CMD NOTFOUND GetAttributes
6 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT.PIF NOTFOUND GetAttributes
7 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT.COM NOTFOUND GetAttributes
8 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT.EXE NOTFOUND GetAttributes
9 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT.BAT NOTFOUND GetAttributes
10 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT.LNK NOTFOUND GetAttributes
11 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT.CMD NOTFOUND GetAttributes
12 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.PIF NOTFOUND GetAttributes
13 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.COM NOTFOUND GetAttributes
14 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.EXE NOTFOUND GetAttributes
15 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.BAT NOTFOUND GetAttributes
16 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.LNK NOTFOUND GetAttributes
17 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.CMD NOTFOUND GetAttributes
18 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.PIF NOTFOUND GetAttributes
19 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.COM NOTFOUND GetAttributes
20 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.EXE NOTFOUND GetAttributes
21 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.BAT NOTFOUND GetAttributes
22 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.LNK NOTFOUND GetAttributes
23 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT.CMD NOTFOUND GetAttributes
24 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT.PIF NOTFOUND GetAttributes
25 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT.COM NOTFOUND GetAttributes
26 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT.EXE NOTFOUND GetAttributes
27 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT.BAT NOTFOUND GetAttributes
28 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT.LNK NOTFOUND GetAttributes
29 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT.CMD NOTFOUND GetAttributes
30 00:55:06 Explorer:FFFC292F Attributes C:\XIT NOTFOUND GetAttributes
31 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\SYSTEM\XIT NOTFOUND GetAttributes
32 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT NOTFOUND GetAttributes
33 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\XIT NOTFOUND GetAttributes
34 00:55:06 Explorer:FFFC292F Attributes C:\WINDOWS\COMMAND\XIT NOTFOUND GetAttributes
35 00:55:46 Filemon:FFFFB79F Attributes C:\XIT.PIF NOTFOUND GetAttributes
OS: Windows 98 SE
Reply 38 of 93, by asdf53
DustyShinigami wrote on 2025-11-06, 01:02:
Okay, this at least tells us it's not an external program calling "xit", it's Explorer. It could be an explorer shell extension that causes this error because these extensions run within the explorer.exe process.
https://www.nirsoft.net/utils/shexview.html
This tool allows you to list the currently installed shell extensions. Do you have any installed that are not from Microsoft? The next step would be to examine their DLL file to see if it implements ShellExecuteEx.
Reply 39 of 93, by DustyShinigami
asdf53 wrote on 2025-11-06, 15:45:
Okay, this at least tells us it's not an external program calling "xit", it's Explorer. It could be an explorer shell extension […]
Awesome. Thanks for the suggestion. I'll give that a try in a minute. I'm sure the error will pop up again soon. It seems to be doing it frequently again.
OS: Windows 98 SE
