Reply 20 of 40, by egbertjan
egbertjan wrote on 2025-11-13, 12:42:When I start the computer with a good working videocard I hear one beep. When I start the computer with the Speedstar I hear a m […]
nuno14272 wrote on 2025-11-13, 09:07:If no boot, and no beeps, the card is causing a short...
If bios problems the cpu would post , no video on screen but post.so its a short problem.. need to check continuity in those tantaluns, and that diode
When I start the computer with a good working videocard I hear one beep. When I start the computer with the Speedstar I hear a multiple beep and I hear the harddisk startup, nothing on the screen.
So, I don't think there is a shortcut. I'll be back when I know the exact beeps.When I want to check the capacitors, do I have to remove them first from the card?
I listened carefully to the beeps: one long en three short. In the meantime I also tried BIOS 2.0, no result whatsoever.
