Help with a 440LX build
Reply 20 of 138, by shevalier
Let's be honest, any PCI SATA controller will be faster than the UDMA33 built into the 440 chipset.
It is Silicon Image that provides UDMA66-level performance.
On the I815 with UDMA100, the IDE bridge to SATA (based on Jmicron) is already faster.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 21 of 138, by hydraphone
Thanks so much for the responses, guys! I'm pleasantly surprised how great this community is.
shevalier, unfortunately, I fdon't have a CD-ROM drive of FDD, yet.
Chkcpu, thank you so much for taking time to looking into & diagnosing the issue. That was extremely helpful! I totally forgot about the AWARD BIOS 32GB limitation and the 32GB jumpers that was present on some of the HDDs back then, what a blast from the past!
I'm curious & would like to learn about the tools you've used to look into the BIOS files. For some reason, the Award BIOS Editor doesn't recognize the microcode for example.
Now that we know what the issue is, with regards to how to proceed with the BIOS upgrade... I ordered an SD-to-IDE adapter and will first try the 8GB SD card I found lying around at home. However, the options you mentioned are also interesting, and will be my backup plan
- I used to have an EEPROM programmer ~20 years ago, but alas, no longer. It looks like ~$70 these days.
- There are IDE HDDs with 10-20GB capacities on eBay, but of course,II will also need to buy some sort of adapter to write anything into them using my modern computer.
- With floppy, I will have the similar issue, how do I transfer files into a floppy in the first place. But perhaps you're referring to FDD emulators like the GoTek one, which are currently seeling at $24.
- I'm wondering if limiting the HDD capacity by manually entering cylinders (<65536)/heads/sectors in BIOS as well.
All good options worth trying, the only point to consider is of course the cost.
maxtherabbit, of course, you do you. But I prefer having a USB 2.0 card, I have used those before back in the day, and they are a plus to me. But I'm curious as to what kind of workload do you have in my that would be bottlenecked by the CPU usage of the USB 2.0 card? For file transfers from a USB disk, it is a substantial improvement, and I wouldn't mind it keeping the CPU busy during those transfers. Another use case for me is USBODE-CIRCLE, which has known issues with USB 1.1. If you're referring to games, Celeron 466MHz is actually already overkill for the games that I'm planning to run on this computer. Games from 2000+ run fine on my modern desktop anyway. Another use case, the mainboard has only 2 USB 1.1 ports, which is too few.
douglar, thank for the suggestion. I will try the Rosewill RC-212 (which is also VIA) and see how it goes. As shevalier pointed out, the internal IDE with UDMA33 is already a low starting point, so any PCI-SATA that works sould be an improvement. I did see Promise S150 TX2 recommended in a different thread as well, but the cheapest one I was able to find is $175 on eBay which is too much to justify this hobby project.
Reply 22 of 138, by hydraphone
Back to the 120GB SSD.
Prepared a bootable disk with the lite FreeDOS image (32MB), and then the copied Award Flash Utility 7.96 along with the new BIOS in it.
Manual CHS settings (1024/16/63, ~528MB) in the BIOS with IDE2SAT2 + 40-wire cable didn't work either, it still hangs at the same BIOS screen, once the HDD detection finishes.
Waiting for the SD-IDE adapter to try next.
Reply 23 of 138, by maxtherabbit
The issue with the USB 2.0 cards isn't that they occupy the CPU when you're actively doing file transfers, it's that they do it when you're not. There have been many threads here on it over the years.
Reply 24 of 138, by MattRocks
In response to the OP: Test with a small SATA HDD instead of the SSD.
If the BIOS detects the HDD -> SSD quirks need resolving.
If the BIOS fails to detected the HDD -> Adapter quirks need resolving.
Milestones [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i5) → x86-64(i7) ] * original lost
Reply 25 of 138, by douglar
Some people report issues connecting via sata controllers with sata 2 or sata 3 storage, but I don’t think that’s a guaranteed problem. Might be more of a bios issue. There are a lot of bios images you can try here: https://theretroweb.com/chips/4807 I’d love to hear what combo works for you.
Reply 26 of 138, by hydraphone
maxtherabbit, I don't remember being bother by that in the past, but it's been more than 2 decades, I'll check it. Thanks for letting me know.
MattRocks, thanks for the suggestion. The smallest HDD I have is unfortunately 2TB, so that would be something I'd need to buy. Good advice.
douglar, worth a try indeed, the brand-less SATA PCI card that I have seems to have the EEPROM SST39SF010A which may not be usable according to some other threads here, but once I get the system up and running, I will try to flash it nonetheless and if that doesn't work will try to mod the BIOS to include the PCI ROM as suggested above. In the meanwhile, Rosewill RC-212 should arrive soon, which is supposed to have a functional BIOS of its own.
Reply 27 of 138, by NeoG_
Sounds like all of your storage related issues will be solved with the SD to IDE. It will be a fixed disk on the old system and also allow you to write files to it on a modern system. It's the route I ended up going down as well, although I use it along side a 20GB IDE HDD to get some clicky-clacky as well.
If you have no other removable storage at all, you will need to make the SD card bootable with DOS and also copy the OS disc files onto it using your modern system. The easy way is to use the pre-made SD image that some kind soul uploaded to IA: https://www.youtube.com/watch?v=rmx3SzRaNYA
Reply 28 of 138, by hydraphone
NeoG_, the fact that this is a thing is reassuring to know, thanks! The SD to IDE adapter will arrive tomorrow.
However, I just had a success by defining a 8GB HPA using
hdparm -N p16514064 --yes-i-know-what-i-am-doing /dev/sdX
it gave a bunch of errors
setting max visible sectors to 16514064 (permanent)
SG_IO: bad/missing sense data, sb[]: 70 00 01 00 00 00 00 0a 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
max sectors = 16514064/1, HPA setting seems invalid (buggy kernel device driver?)
but after disconnecting & connecting the device to my modern computer, fdisk shows 7.68GiB. I put this back into the retro computer, and it worked! I reflashed the BIOS. Finally, I'm in the business 😀
Once I install Windows 98, I'll play around with the no-name SATA PCI card until Rosewill arrives.
Still waiting for the new NEC based USB PCI card to be delivered as well.
Reply 29 of 138, by hydraphone
For anyone planning to use hdparm -N, before you do anything, make sure to note down the number of sectors in your device, using
fdisk -l /dev/sdX
for example. You will need this number to restore your drive back to its original size afterwards using
hdparm -N p<originalsectors>
Reply 30 of 138, by hydraphone
Installing Windows 98SE without a CD-ROM drive or floppy drive has been a bumpy experience. I ended up creating a virtual machine in 86Box with .img type HDD, made the initial stage of the Windows 98SE installation there, copied the WIN98, and dd'ed the .img file into the SSD.
Reply 31 of 138, by hydraphone
The saga goes on, I first installed the chipset drivers. Next is graphics card.
I have a GeForce FX 5200 PCI card from PNY with 128MB VRAM. After installing the drivers, things go awry. I first went with 45.23: any change in resolution/bit depth causes the computer to reset itself. After re-installing W98SE, I went with 56.64 drivers. This time, after installing & rebooting, it is stuck at splash screen, and then eventually reboots, similar to what is reported in FX5200 Cards Hang PC
It's connected to the only monitor I have with VGA input: an Acer R240HY. Could that be the problem? Do I need a new monitor? 😀
Reply 32 of 138, by NeoG_
I used an FX5200 AGP in a 440BX using 45.23 drivers without any issues, I think many people are using a similar configuration. I would try different PCI slots and also disable any other PCI bus devices you can, see if it works in a minimal configuration. Also try cleaning the card contacts (deoxit and magic eraser works wonders) and giving it a few insertion cycles.
Reply 33 of 138, by hydraphone
NeoG_, what kind of monitor did you use it with?
The graphics card was new old stock, but the mainboard wasn't and given its age it looked pretty decent and clean, but indeed, who knows what lurks in those PCI nooks and crannies. Were you referring to the PCI slots in the mainboard?
There are 5 PCI slots. Yesterday, I had the FX 5200 in PCI slot #4, and Audigy in #3, with parallel & serial ports disabled from the BIOS. Today, I removed the Audigy, and rotated the FX 5200.
Slots #2,3,5: no lock up, but only getting a very limited set of resolutions & bit depths in the display settings, up to 16-bit depth and from 640x480 to 1024x768. The only setting that works is 16 colors 640x480.
Slot #1 (the one closest to the AGP slot): it worked!
Any ideas about what is going on what it going on with the PCI slots?
Thanks for suggesting deoxit & magic eraser, I'd like to do it nonetheless ---shopping list keeps growing 😀
Reply 34 of 138, by NeoG_
hydraphone wrote on 2025-11-30, 19:18:
I used it with a DiamondView 1770e CRT and also a Dell P2014H LCD, both via VGA
While PCI is a data bus and transfers/addressing is common to all slots, IRQ routing and sharing is still a bit funky with different slots so it might be that the graphics card likes whatever IRQ config is on the first slot. It's not uncommon for people to need cards to be in certain slots for things to be stable.
Also, dirty contacts can also cause all sorts of problems. EG maybe the DDC pin on the monitor cable wasn't contacting properly and now it's been plugged in a few times it can now read the monitor data. It's possible that even NOS card contacts are covered with something and now that the card has been inserted a few times it's rubbed off enough stuff from the card or slot pins for it to make proper contact now.
Reply 35 of 138, by hydraphone
Interesting. I'll also try the PCI Latency Tool to see if there's anything off with slots #2-5.
The VGA cable is brand new, so that probably was fine.
Now, I'm trying to use the sound card, and Audigy 2 ZS. Whichever PCI slot I plug it in, once I install the drivers (if I can, sometimes it reboots during installation) and reboot, one of those happen: it tells me the card is not installed properly, windows freezes which recognizing IEEE 1394 Host Controller, or it keeps rebooting before the desktop appears... I'm wondering if there is something wrong with the motherboard. I don't remember any issues like this back in 1999 with a similar computer.
Reply 36 of 138, by hydraphone
Well, there were differences of course, I had an AGP Voodoo card and a Sound Blaster PCI 64( or128?), along with some other PCI cards.
Reply 37 of 138, by MattRocks
I had TX and BX motherboards. The magazines I read the 1990s insisted that PCI slot #1 has shortest path or least interference so put VGA card there, and recommended putting the sound card in the last slot (as sound was considered least critical). I always followed that advice so never learned what happens if you play it differently.
Reply 38 of 138, by douglar
It could be many things. It’s possible that the act of removing and reinsert thr cards was enough to clean the contacts. Does the problem return if you put the cards back in the original configuration?
Reply 39 of 138, by hydraphone
MattRocks, that makes sense. It still is the case today, as far as I know.
douglar, indeed, if I change the position of the graphics card (without other cards), the problem returns.
As for the sound card, I placed it to PCI slot #3, and I used the Audigy 2 ZS CD from Vogons this time, and installed the drivers (which installs WDM drivers). After restarting Windows, it froze at Windows splash screen & reboot itself after several minutes. Following I Re: Guide: Installing Windows 9x and DOS drivers on Audigy cards (version 3.0) I disabled Firewire device and the reboots stop, but there was no sound. Then, using the Driver Utility Program Phil pointed out https://youtu.be/RfmYYG1rVug?t=402 I switched to VxD drivers and the sound worked. Quite puzzling, I wonder if anyone has an insight to what the issue could be with regards to the sound card.
But I'm glad that despite all the quirks, I have a minimally-functioning system now!
