Reply 20 of 20, by shevalier
- Oldbie
maxtherabbit wrote on 2025-12-12, 13:40:jmarsh wrote on 2025-12-12, 12:23:I really can't see the point in this, there's going to be a cable attached to the port either way so what does it matter if it's extended by ~8cm with an adapter cord?
honestly this, whole topic is pretty damn silly
not to mention you can buy premade cables with the correct connectors already attached if you're antidongle
To be honest, at this point, I don't really care anymore.
This dongle burned out one TDM channel on my monitor (the entire image is red via the DVI connection) and only VGA works.
But you can continue to try your luck.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
