Questions about Sound Blaster variables
Reply 20 of 20, by DustyShinigami
NeoG_ wrote on 2025-12-12, 02:07:
DustyShinigami wrote on 2025-12-12, 01:30:
It's the normal autoexec.bat file. But yeah, I've been advised to use a separate one. Either to use DOSSTART and/or a PIF file. The only thing is, I don't often load Windows first and then go to DOS via a custom file. I usually access DOS on boot from a boot menu.
If you want to use the native boot menu to make different environments, you can separate your config.sys and autoexec.bat for windows and DOS like this
How to create a boot (start up) menu under Windows 9x/ME
Awesome. Thank you. I’ve been pointed to various threads/sites on how to setup a custom boot menu and I’ve not really understood what does what and why. This guide looks a bit more promising so hopefully it’ll be easier to understand and follow along. 😃
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
