Reply 20 of 35, by thewhiteambit
Falcosoft wrote on 2025-12-14, 12:14:thewhiteambit wrote on 2025-12-14, 12:03:Falcosoft wrote on 2025-12-14, 11:37:@Edit:
I have also tested this with an I7-4770k on a GA-Z97X-UD5H board and it works the 1st time after a cold boot. If I restart DOS with Ctrl+Alt+Del after 1st successful usage and start the TSR again then it does the same as on the Phenom II X4 system. That is it restarts the system after Step 3.Strange observation. What happened when you try to run it a second time after successful run without rebooting?
It seems I can run many instances of the TSR without any problems in the same DOS session and the test application (DOS64USE.COM) can communicate with the active ones.
Maybe it's a BIOS quirk. I will try to determine what conditions are necessary exactly to reproduce the problem.
I didn't remember the step numbers correctly either, but initializing is a bit early/unexpected to crash. Crtl-Alt-Del not allowing to run sure sounds like a Bios quirk. What happens when you Reset, Boot to DOS, press Crtl-Alt-Del without running it and try it after that? Still crashing?
