Reply 20 of 21, by tehsiggi
- Member
douglar wrote on 2026-01-16, 19:51:I tool the heat sink off my Apple Radeon 9600xt and it had an R360 chip-- https://theretroweb.com/chips/4165 […]
Ozzuneoj wrote on 2026-01-12, 19:35:I have one of these Apple 109-a58503-20 cards and I just pulled the heatsink off to see what it says. It says 9600 Pro on the die. Also, I used digital calipers and measured the die at ~8.86x8.86mm with is roughly the same as the 76mm^2 reported for the RV350 ... for what that's worth.
Looking at your chip-- The part number ends with an "11F" instead of a "13F". That suggests to me that you might have the 110nm die shrink R351, not the 130nm R360. But I also see chips that end 12f and 11fl, so I don't really know.
The number refers to the revision, not directly to the process. The Radeon 9800 databook gives some insight here:
