Reply 20 of 71, by Nicolas 2000
st31276a wrote on 2026-01-23, 19:59:FM synth should play through the OPL3/CQM synth and general MIDI through the wavetable addon or external synth plugged into the gameport.
There is nothing on the gameport atm, I'll use it for joysticks. I'd like to use simple internal midi sounds, but as I have no wavetable addon that will not be possible? Or does W3.11 already have a software solution for that?
