Reply 20 of 20, by DLL hell
- Newbie
ott wrote on 2026-02-23, 13:28:This is normal behavior, Q-Flash only supports floppy. […]
DLL hell wrote on 2026-02-23, 06:48:I'm running out of luck, My flopy drive doesnt work and My qflash can't flash with a USB drive. I'm gonna try to get a floppy drive from a friend , but, for now i'm gonna try the unebootin usb method to install Windows nt as a temporary solution...
Alternatively, you can update BIOS from clean MS-DOS. I use Windows 98 CD-ROM for this purpose.
Gigabyte's BIOS update archive already comes with the flash utility (FLASH891.EXE) and autoexec.bat command.
You need to unpack archive (7-Zip executable archive) to HDD with FAT32 partition.
I captured the complete update process on my motherboard for reference:
I also remembered this BIOS option that might help:
For installing and using Windows NT it is necessary to limit the maximum CPUID to 3
I hope this helps. Good luck!
Update: i have two brand new used iDE cables and now i can boot from any CD ROM, Made a quick test with old copy of Windows nt 4.0 and now i AM up an running, next step Will be upgrade My BIOS to the latest available...
