Reply 20 of 22, by DustyShinigami
- l33t
jh80 wrote on 2026-02-26, 22:38:I just checked using only the YMF-719 and I did not get any hanging notes. […]
I think this is a CPU speed-related issue, perhaps related to the patch Dusty is using.
Dusty: Can you try slowing down your CPU and not using the S&M patch?
I'm not familiar with disabling cache on a Pentium II, but a quick search suggests disabling both L1 and L2 on a Pentium II will put it in 386 speed territory, which might be enough to run S&M.
I can try, though others in that other thread also tried slowing the CPU down. I'm not sure if disabling the L1 cache is wise though. When I tried before, it made the PC incredibly slow. It wouldn't even get passed the Windows splash screen. The most I can do is disable the L2 cache and try different speed levels. I think CPUSPD has opens between 1-8 with 8 being the fastest.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
