Reply 20 of 20, by rasz_pl
Xicor wrote on 2026-10-23, 20:49:
Today I received a couple of N28F010, and I'm happy to report that the recovery method works like a char
vrob98 wrote on 2026-10-24, 18:52:
Quick feedback: it works! 😀
Ok, I reconnected the Vpp voltage and gave it a try - the recovery process works with the external floppy drive too.
Without a proper populated flash it sings (beeping), and checks continually the floppy drive, like an Amiga does. As soon as a floppy is placed with the files, there is a succession of floppy reads and short beeps that probably signals the flashing and checksum routines. At the end the machine resets, and boots normally.
Also a picture of the riser, it is as simple as it gets.....
Thank you, so riser is 1:1 meaning its an ordinary ISA slot.
Xicor wrote on 2026-10-23, 21:09:
Also, checked the contents of the recovered flash and it differs from my initial backup in 2 Bytes, in addresses 803A and 803B.
offset 3A char mm[2]; // minutes 22
Hmmm, did you remove RTC battery before running recovery? otherwise Date should be whatever was in RTC.
Hypothesizing again: your original BIOS has 22 there because your particular computer spend 22 minutes at the factory running some burn-in tests before arriving at the BIOS flashing station 😮 And when you ran recovery you didnt wait at all = 00 minutes.
