Reply 20 of 42, by Falcosoft
radozd wrote on 2026-04-09, 06:26:
Version 3 is here
I'm not entirely sure why I keep doing this, but I seem to get a kind of forgotten enjoyment from exploring old FTP servers.
Hi,
I could not use version 3 since it gave me 'Not enough free memory' right at start. This happens because of the increased max item size to 2000.
I have MS network stack also loaded under MS-DOS that eats up quite a lot conventional memory.
So I downloaded the source to compile a max items = 1000 version for myself but I got build errors in UIAPP.CPP:
1. at line 757 ->
bool UiApp::IsViewable(const const UiEntry *e) const
. After removing one of the 'const' the error disappeared.
2. at line 764 ->
 const char *ext = strrchr(name, '.');
After modifying name to e->name the error disappeared.
So finally I succeeded in building an 1000 max item size version for myself but I still think that a run-time configurable max item size would be better.
Bye.
@Edit:
BTW, I do not think that restricting the quick viewer to only .txt/.diz/.ion extension is useful in any way. The user most likely knows better what file has text content. Removing this restriction would enable the user to view e.g. html or server config files (that usually have no extension at all) as well.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 21 of 42, by radozd
Right. I forgot to move the latest sources to my macbook. Updated.
Still 2000 files vs 1000 files take only ~30k+~30k = 60k bytes more.
How much free memory do you have?
Reply 22 of 42, by Falcosoft
radozd wrote on 2026-04-09, 08:13:
About ~ 450 KB free.
This is a relatively 'modern' system (i7-4770K) with AHCI option ROM etc. so you cannot get the same amount of free conventional memory as on retro systems.
Website, Youtube
Reply 24 of 42, by Falcosoft
Hi,
I also think that in UiApp::IsViewable() the
if( e->size > 4096ul ) return false;
check is unnecessary since later when the file is opened and read in UiApp::QuickViewCurrentItem() it is truncated anyway to a fixed size buffer.
With the file size and extension check removed you could preview the beginning of any files.
Website, Youtube
Reply 25 of 42, by radozd
Falcosoft wrote on 2026-04-09, 08:55:
Hi, I also think that in UiApp::IsViewable() the […]
Hi,
Without any limit 1GB text file must be downloaded and then cut to 4k.
I need to implement memory mode and partial downloading to do this properly.
Reply 26 of 42, by Falcosoft
radozd wrote on 2026-04-09, 09:01:
Hi,
I do not think that 1GB text files are that common 😀
But OK, then you should raise the size limit to at least 64K (4K -> 64K files are much more common) since the file size limit does not have to be the same poor 4k as the read buffer size.
Website, Youtube
Reply 27 of 42, by Grzyb
macbook
Hehe, so that's where the "__MACOSX" directory comes from 🤣
For a DOS program, it's just garbage...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 29 of 42, by Grzyb
BTW, consider advertising your program here - Anyone know a DOS FTP Client with GUI or shell
People have been looking for something like this for ages, make sure they don't miss this!
Reply 31 of 42, by radozd
Falcosoft wrote on 2026-04-09, 09:07:
3.1
64K + reduced memory footprint. I hope it will be enough.
Reply 33 of 42, by Grzyb
That "pulse indicator" seems unnecessary - there's already the status line with progress display.
Consider adding a normal progress bar instead.
BTW, I find it strange that the transfer starts immediately on F5 - consider adding a dialog with the option to edit the destination filename.
Reply 34 of 42, by radozd
The pulse is mainly useful for very slow servers, where even a directory listing can take seconds and it’s otherwise unclear whether anything is happening.
In other cases, I don’t see a strong need for it.
Reply 35 of 42, by MarmotaArmy
radozd wrote on 2026-04-15, 12:15:
For ages I was searching a FTP program with panels like this one and there was none.
You are a pioneer, building something new. Please keep up the good work, Thanks a lot!
Reply 36 of 42, by soggi
This is really great, despite I don't need it myself!
I will add FTP2P (a link to link https://github.com/radozd/ftp2p/) and a link to this thread for ongoing support to my tools section (https://soggi.org/misc/tools.htm).
Thank you very much!
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 37 of 42, by mbbrutman
@radozd
Instead of copying all of mTCP into your project, I've uploaded mTCP to github: https://github.com/mbbrutman/mTCP.git
It's probably better to reference that as a dependency or fork it and add your files to the fork. That way you can see when mTCP changes and update accordingly.
Reply 38 of 42, by radozd
@mbbrutman, thanks! I'll consider revisiting the project structure.
Reply 39 of 42, by radozd
Ok, FTP2P now uses upstream mTCP as a Git submodule.
It is still v3.5, because nothing has changed in the FTP2P code since the last release. I am quite satisfied with the result already. 😀
If you need the build details, please see the README / build notes in the repository.
