486 quake race
Reply 20 of 34, by feipoa
Dan386DX wrote on 2026-05-28, 22:49:
In that case, have I misunderstood your ultimate comparison results where the POD achieved what looked like the best scores at 20.8 stock + 24.4 @ 100?
Or did you manage the 21.8 a bit later?
It looks like you are mixing up the Pentium Overdrive results with that of an Am5x86-180. This thread is asking about the best DOS Quake results when using an AMD 5x86, not a Pentium Overdrive in a socket 3. An overclocked POD will always beat an overclocked Am5x86 in DOS Quake. If you are interested in POD results, look for threads in the 110-125 MHz range.
Reply 21 of 34, by Dan386DX
feipoa wrote on 2026-05-28, 23:25:
Hold up, yeah I got that we're not talking about POD here.
What I'm saying is, in the ultimate 486 comparison, the best Quake result seems to be 20.8 at stock - and that is scored by a stock POD.
But it looks like the 180MHz 5x86 scores in this thread score higher than that?
90s PC: IBM 6x86 120Mhz. 128MB/6GB. ATI Rage Pro 3D.
Boring modern PC: R9 3900X, RX 7800XT. 32GB/1TB.
Fixer upper project: NEC Powermate 486SX/25. 16MB/400MB.
Reply 22 of 34, by feipoa
An overclocked, and system optimised, Am5x86 at 180 MHz will outperform a non-overclocked Pentium Overdrive 83 MHz in DOS Quake. The 486 benchmarks do not include system optimised Am5x86 benchmarks at 180/200 MHz.
Also, most of those benchmarks were run on an M919 which implements an automatic 2/3 PCI frequency reduction when run with an FSB of 40/50/60 MHz. This was not known when running those benchmarks. To further the separation in results, the POD benchmarks were not on M919 (they were run on an MB-8433UUD) because the M919 doesn't work properly with the POD in L1:WB mode.
Reply 23 of 34, by Leo1976
bertrammatrix wrote on 2026-05-28, 19:48:
21.2 on mine @ 180mhz. Score goes up a tad at 200 but since I normally use it at 180 that's the "official" score for me
M919, 1mb L2, matrox g200
Also a very nice result!
Reply 24 of 34, by SquallStrife
Dan386DX wrote on 2026-05-27, 21:35:
Correct, the Pentium's strong FPU gives it a huge advantage over most 486s
It's less the performance of the FPU itself (though that certainly helps), but more the superscalar design of the processor as a whole. This is what prevented other Pentium-class processors from AMD and Cyrix from performing as well in Quake.
Reply 25 of 34, by Sebas1983
Hi,
My highest score is 24.0 fps in Quake 320x200 with an AMD 5x86-133@200 4 volts (Peltier cooling) on ​​a Pcchips M919, Pancake Puppies 1MB cache stick with 10ns chips, 32MB EDO, TNT2 M64 pci@ 66mhz pci bus and the fastest timings in the bios possible.
I have tested 150+ memory modules to get the setup stable at the fastest timings.
Greets Sebastian
Reply 26 of 34, by Dan386DX
feipoa wrote on 2026-05-29, 04:26:
Thank you for explaining. That makes good sense!
Reply 27 of 34, by Dan386DX
SquallStrife wrote on 2026-05-29, 15:20:
Interesting. AFAIK, the 6x86 is superscalar on the integer side, but its FPU was essentially a 387-class design and obviously far behind Pentium. In Quake,which is heavily FPU bound, I'm sure that FPU was the 6x86 choke point?
Reply 28 of 34, by Leo1976
Sebas1983 wrote on 2026-05-29, 23:25:
Hi, […]
Hi,
Greets Sebastian
Wow!
That must be the new record !!!
Reply 29 of 34, by bertrammatrix
Hi, […]
Hi,
Greets Sebastian
Oh wow, that's impressive!
Is that on a full system, or is it just barebones mobo + video?
Indeed, memory/cache combination plays a big role, definitely lots of alchemy involved. I could never get success at 0/0ws at 180/200 - my cache module only has 12ns chips and have only tried 30ish memories, so clearly there is still some room for improvement.
Is the ram something special (40-50ns) or just something regular?
Reply 30 of 34, by feipoa
Hi, […]
Hi,
Greets Sebastian
Is the system stable when mounted inside a case? Does it run Windows 9x games? I've seen many systems stable on the bench only to fail with a little increase in ambient temperature (inside the case).
Reply 31 of 34, by leileilol
The pentium is going off some abrash trick to do painting twice in one go. If DOS Quake were compiled without the d_ ASM, the results between the 486s and the Pentiums would be a bit more fair (though obviously slower for both)
(also i've grown tired of a lot of pentium snobbery having played Quake online a 1997 ago on an am5x86...)
long live PCem
Debian's fucked
Reply 32 of 34, by Sebas1983
bertrammatrix wrote on 2026-05-30, 16:33:
Oh wow, that's impressive! […]
Hi, […]
Hi,
Greets Sebastian
It is just barebones mobo + video.
I tried various 45 and 50ns modules, but they were not stable. I achieved this score with a 60ns module with Hyundai chips.
Reply 33 of 34, by Sebas1983
feipoa wrote on 2026-06-01, 08:48:
Hi, […]
Hi,
Greets Sebastian
I haven't tested that yet. I've only done some benchmarking in DosBench.
Reply 34 of 34, by rasz_pl
leileilol wrote on 2026-06-01, 17:04:
shockingly no, 486Quake recently renamed to https://github.com/goshhhy/TurboQuake, did just that, replaced some assembler optimizations aimed at taking full advantage of pipelined FPU and results are quite surprising. It somehow runs faster on all CPUs equally 😮 that is Pentiums still somehow get faster despite replacing fxch tricks with more classical serial FPU code. K5/K6 get some gains, but those are miniscule and still get crushed by Intel.
results from the readme:
cpu					| stock	| 486quake	| 586quake
AMD 5x86/133 | 16.4| 18.4 |
Intel 486DX4/100 | 9.6 | 10.9 |
Cyrix 486DX2/66 | 6.3 | 7.1 |
Pentium 133 (P54C) | 35.6| 39.6 | 41.0
AMD K6/166 | 32.5| 37.8 |
AMD K6/133 | 28.5| 33.0 | 32.2
Cyrix 6x86MX PR166 | 26.3| 30.3 | 29.7
AMD K5 PR133 | 25.8| 28.9 | 29.0
Cyrix 6x86 PR166 | 23.9| 27.9 | 27.1
Cyrix 6x86L PR166 | 23.5| 27.6 | 27.1
