Reply 20 of 21, by Shponglefan
momaka wrote on Today, 19:14:
I wasn't identifying capacitors by their color and not sure where you assumed this from.
I think they might have misinterpreted my original post. I referenced the capacitors by color, because I marked them with different colors on the photo I posted. I simply wanted to have a way to reference which caps were which.
I think may have misunderstood that to think I was referencing the physical colors of the caps themselves.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 21 of 21, by Shponglefan
I ended up placing an order with Digikey for polymer caps with a handful of different specs. I'm curious to measure them when I get them, especially to see what my ESR meter reports.
In the mean time, I removed all the 3300uF caps from the board and cleaned things up. It's ready for replacements.
I'm going to initially leave the 1500uF caps and test things to see if the board works. Depending on how that goes, I'll decide later if I want to also replace them.
The attachment DFI ITOX G4E620-N 3300uF caps removed.jpg is no longer available
