Reply 20 of 22, by DaveDDS
- Oldbie
MattRocks wrote on 2026-05-10, 14:17:... It was after WinXP had logged on, recognised that the VGA card had changed, completed device detection, and was applying automatically selected drivers - the moment when you'd expect the resolution to successfully change is the moment the screen went blank and keyboard lights went out. Total hard crash. On the next POST the artefacts were present.
It feels like something shorted in the graphics card.
Yes, does feel more and more like bad caps.
At least with artifacts now "most" of the card is working. Have you pulled the caps and seen if any are shorted and if they measure close to their marked values?
Could also be a bad ROM or RAM ... Are the artifacts consistent? ... if they come/go/move it's more likely noise/bad caps, if consistent "bad spots" I'd be more suspicious of memory.
But given it's age, I'd definitely check caps first.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
