Choosing a compiler for retro coding?
Reply 20 of 22, by RetroPCCupboard
I have been using Borland Turbo C++ for my retro programming. I am programming in C, and I am still learning, but I find it to be quite a fast compiler, and the debugging seems to work quite well. However, I do find the compiler errors to sometimes be hard to decipher. I do miss some of the niceties that you get in more modern IDEs though. Especially autocomplete.
Also the DOS text mode editor doesn't let you see much code at once compared to what I am used to in my day job of programming in C# and Javascript.
Reply 21 of 22, by jakethompson1
RetroPCCupboard wrote on 2026-07-20, 15:13:
What if you put ansi.sys in config.sys, and mode con lines=50 in autoexec.bat?
Reply 22 of 22, by OzzFan
Agreed! Autocomplete saves lots of time typing and wider / higher resolution screens allow us to see more of our code. The frustrations are real.
Hobbyist Developer : https://www.shelteringoak.com/du/
