Reply 20 of 28, by badmojo
Barley wrote on Yesterday, 22:17:
When I get a retro machine just the way I like it, I start planning backup parts. It's only going to get harder to find replacement parts so I make sure I always have backups.
Oh, there be backups 😅
Reply 21 of 28, by SiBurning
I'm old enough to not need to build a retro rig. I built my surviving gaming box in 1999. Since then, I've only changed the case (because I misplaced the side panels and the front panel broke), and the power supply (which was no longer stable and not worth recapping). It's got a celery 300a @450 and 2 isa slots, which is all I need for DOS & Windows 95. There's all kinds of utilities still on there to slow things down if need be or do freaky memory hacks (qemm and junk like that). The one thing I managed to lose is the low level disk backup software, but it's easy enough to do that offline nowadays. I still have a 32-bit Windows 7 laptop to play later games that have protection. Anything later works on modern hardware. I happily chucked a dozen boxes, from a 286, 386s, a VLB something or other, a 486, a couple of pentiums, and a dual athlon space heater. I suppose all the cards, cpus, motherboards, and memory I chucked is CRINGE, so I won't say. Hey! I totally understand the attraction, but I'm happy to avoid any more busted knuckles. Carry on.
Reply 22 of 28, by NeoG_
My systems are never "finished" as in i am constantly thinking of things to do with them, but after every checkpoint they are fully working. So at least I can use them and they don't sit around in a non working state.
Reply 23 of 28, by RetroPCCupboard
Shponglefan wrote on Yesterday, 23:38:
I came up with a list of period correct systems from 1993 to 2000. Actually doing specs was pretty easy since I just went with the best-of options for each year.
Did build systems for 1994, 1995, and a pair for 1996. But then got distracted by other types of builds along the way, especially "all-in-one" builds and experimenting with Pentium 4 setups (imho, still a vastly underrated retro platform).
Have pretty much all the parts for the rest of the period correct builds, just haven't gotten around to building them yet.
What hardware did you go for on your 1996 builds? My planned machine, which is closest to 1996:
DOS 7 / Early Win95 (1993-1996)
DirectX 3, Glide 1
(Can slow to the speed of a 486 by disabling caches and using SETMUL)
Pentium MMX – 200-300Mhz (Jan 1997) with Front panel switch to control FSB between 66Mhz and 100Mhz
Gigabyte GA-5AX Super Socket 7
64Mb PC100 SDRAM
S3 Virge 2mb (1996) + Voodoo 1 4mb (Oct 1996)
Soundblaster 16 CT2230 and Diamond Monster Wavetable 2Mb
3.5" floppy drive 1.44mb
100Mb ZIP Drive
IDE CD ROM drive
HDD caddy for easy access to storage
Horizontal ATX Desktop PC
Gameport Joystick
I realise that AWE64 Gold is probably more period correct, but I want real OPL3 for my DOS games. I see this as being my primary DOS machine.
Reply 24 of 28, by RetroPCCupboard
Yeah, I have similar thinking. I have spare parts for some of my planned builds. But some parts are so expensive now, that I just can't afford it. Maybe it would have been a possibility if I'd been less ambitious on the number of builds. Haha.
I only have one of AWE64 Gold and only one Geforce FX 5900 Ultra, and one Voodoo 3500, and one Radeon 9800 XT. Likewise there are some motherboards that are just really expensive now.
Reply 25 of 28, by appiah4
The only change I made to my builds in the last 3 years was turning my single core Tualatin Windows Me build into a dual core Coppermine Windows 2000 Pro workstation. Other than that.. They are all fairly done and over with, sitting in a closet, waiting for my retirement..
Reply 26 of 28, by Joseph_Joestar
appiah4 wrote on Today, 06:15:
Same here. I've pretty much acquired all the retro hardware that I wanted, and built the systems that I envisioned.
I did repurpose a couple of builds over the years, and retired a few as well. Basically, once I had gotten a clearer idea of what I needed, I trimmed down my collection accordingly.
My retro builds
Reply 27 of 28, by RetroPCCupboard
You can't play with them now? I still have 20yrs until retirement (I am currently 47), so I am not waiting that long!
I know it will be a multi-year project to get all of these PCs built. I have 10 new beige boxes waiting to be used, and two cases like this (but in the same silver colour as the drive bays, rather than being black):
The attachment images-1.jpeg is no longer available
Both of the silver cases need restoring though, as the plastic side panels are cracked, and one of them has a broken hinge on the door.
The two jet cases are for a high end WinXP DirectX 9 system (2x Geforce 7900 GTX SLI) and high end Vista DirectX 10 system (2x Geforce 285 SLI).
Reply 28 of 28, by RetroPCCupboard
Joseph_Joestar wrote on Today, 07:08:
Yeah, my ultimate goal is to have a set of systems that are just ready for immediate use. Plus a test bench station so I can make temporary builds for experimenting with or to play any stubborn game that wont run on one of the permanent builds.
