Reply 20 of 29, by Sly_Botts
Dothan Burger wrote on 2026-09-18, 05:29:
Sly_Botts wrote on 2026-09-18, 04:09:
Dothan Burger wrote on 2026-09-18, 02:49:
IMHO if a VIA board doesn't play nice in DOS it's up for sale, they have too many flaws to put up with that. The fact that prices are high may work in your favor, crack somebody else's head. You already have a working system to post pictures to Ebay.
Yeah sb16 emulation in pure DOS usually fails on some Socket 939 boards because the BIOS lacks DDMA / PC/PCI support required by the Creative drivers in pure DOS. My ensoniq audio 1370 fails to emulate in both windows 98 and dos because of this.
Didn't know 939 boards had that problem, I assumed the whole point in bothering with VIA was to get DOS support or at least SB emulation in windows. That sucks because it should've been a killer setup.
I think it was the later socket 939 boards and or the budget boards. It's possible the a8v deluxe doesn't have this issue.
It is possible to commit no errors and still lose. That is not a weakness, that is life.
Reply 21 of 29, by Sly_Botts
Quick update. Now that the system is stable it's performing beautifully. Some of my 3d Mark scores for this GPU at stock are quite impressive. Also, Doom 3 benchmark averages 76-77 on most runs at 1024x768 and 86-88 at 640x480 and I can get Half-Life 2 orange box 2008 edition to maintain a steady 100fps (most of the time). With no AA but x16 AF.
I do have my Ram tweaked to 2-3-3-7 1T. It's cl2.5 mustang Ram 1gb
Reply 22 of 29, by Mister No
Sly_Botts wrote on 2026-10-09, 17:36:
Could you please share what you did in the end to make your system stable? It would be great to have that fix documented for posterity.
Reply 23 of 29, by Sly_Botts
Mister No wrote on 2026-10-10, 07:51:
Don't even use the Sata controller, disable it completely in bios. Use Ide for storage and optical drives. Use a SATA to ide adapter if required.
Ensured the latest bios update installed.
Disabled ECC memory settings in bios
Ensured all settings enabled in the AGP chipset section of bios except the onboard frame buffer size and AGP fast writes. (See image on first page)
Disabled onboard peripherals.
Made sure creative soundcard was in pci slot 2 (only works properly in win98 anyway) do not put a creative card in any PCI slot until bios updated or system will not post.
Make sure you disable anything in the bios you don't plan to use.
Leave plug and play OS set to "no" in bios.
Set IRQ 5 as reserved in bios so sb16 emulation in Windows 98 works.
Installed VIA 4in1 chipset ver.456 first, followed by ver.524a in Windows xp.
Use non creative sound card in XP.
For x800 pro, catalyst 5.13 or earlier only in xp or games crash. For win 98 there is a special 6.2 driver that uses the old control center designed as a final driver for 98/me that works.
For XP install the K8 driver for your socket 939 CPU and the dual core optimizer if it's an X2 CPU.
Install direct X 9c
Install .net framework packages.
Install video driver last.
Install proper monitor driver
Use Refresh lock once monitor driver installed. (Not needed for win 98)
Reply 24 of 29, by Mister No
Sly_Botts wrote on 2026-10-10, 08:37:
Don't even use the Sata controller, disable it completely in bios. Use Ide for storage and optical drives. Use a SATA to ide ada […]
Install direct X 9c
Thank you very much for a very detailed report. I do have some additional questions, though:
1. Were you able to overclock your CPU after you switched from SATA to IDE? If yes, what is the highest FSB your system was stable at? I'm curious if this motherboard can go higher than 225 MHz when using IDE...
2. Did you even try SATA SSDs without overclock (FSB at 200 MHz) in AHCI mode on VIA VT8251 or you have already switched to IDE before trying that?
Reply 25 of 29, by Sly_Botts
Mister No wrote on 2026-10-10, 10:41:
Thank you very much for a very detailed report. I do have some additional questions, though: […]
Install direct X 9c
1. Yes but only to 218mhz x11 (default multiplayer can't change). System became unstable because the PCI slots and the AGP slots also overclock they aren't separate. So basically you can't overclock this motherboard. The system posted but it was unstable in Windows.
2. Yes. I tried SATA before anything else. It allowed me to install Windows XP on a SATA 3 SSD but it was not stable. Files would corrupt and programs would not function properly. AHCI would also not work I had to set SATA to raid mode. Apparently these motherboards or these chipsets or designed that way. What I do know is that if I had a legit sata one hard drive it would likely have worked.
Reply 26 of 29, by Dothan Burger
I'm glad you got that figured out.
Reply 27 of 29, by Mister No
Sly_Botts wrote on 2026-10-10, 13:23:
Install direct X 9c
Have you tried to set [AGP/PCI Frequency (MHz)] under [Advanced] in [JumperFree Configuration] to [66.66/33.33] instead of [Auto]?
This supposedly sets the AGP/PCI lock on this very board.
While you are at it, you can also set the [PCIE Frequency (MHz)] to [Fixed] instead of [Auto], this should supposedly set the PCI-E x1 slot to 100 MHz.
Reply 28 of 29, by Sly_Botts
Mister No wrote on 2026-10-10, 14:11:
Have you tried to set [AGP/PCI Frequency (MHz)] under [Advanced] in [JumperFree Configuration] to [66.66/33.33] instead of [Auto […]
Yes I did that. It ignores it because this motherboard is not capable of seperating the CPU OC from the Slots OCing. Part of cutting costs to make the motherboard. If I had the deluxe board instead of the MX board I likely could but the MX board is their budget board.
Reply 29 of 29, by Mister No
Sly_Botts wrote on 2026-10-10, 14:21:
OK, thanks, good to know first hand that AGP/PCI lock doesn't work, regardless of that setting.
