Reply 20 of 21, by gulikoza
gulikoza
Offline
- Oldbie
This is already on my page 😀
Another difference from the cvs is that 'cycles=auto' is now limited to whatever cycles were set before automatic mode was turned on. This will prevent dosbox from using all the cpu when cycles=auto. If dosbox is started with cycles=auto, the cycles are limited to 150.000 cycles. You can change the maximum with CTRL-F11 and F12.
