Reply 20 of 22, by dvwjr
wrote:Its not fine :( I cant find any of those files in my windows system32 drivers folder, should I download them? how whould i get t […]
Its not fine 🙁 I cant find any of those files in my windows system32 drivers folder, should I download them? how whould i get this to work?
note also that im not using a qwerty keyboard, it's dvorak, but i can type qwerty so I dont care if it thinks it qwerty.
sure, you can upload A test, ill do stuff thats fine.
I already tried booting up, starting command.com right away and waiting till everything loads and then starting system shock, and it did NOT work as i thought it would, I actually need to start the game for it to work. Does this invalidate your test or do you still want me to try it?
You misunderstood about the DIRECTIO.SYS, GIVEIO.SYS, OSAIO.SYS files that I mentioned that might be found in \Windows\System32\drivers. They are EEEEEVIL! If you find any - Purge them, Strike them Mightily - Banish them to the Nether Regions of Hell... 😳 <ahem> They are a lazy programmers way of functioning in a protected-mode operating system like WinXP. They have side-effects (usually bad) for other applications.
Now about your USB Dvorak keyboard. It's the scancodes which count for SYSTEM SHOCK, not the ASCII letter attached to the key that is important for movement and control in the SYSTEM SHOCK code. I am curious about your keyboard experiences with SYSTEM SHOCK running on WinXP. When you do your "quick-before-its-too-late" startup of SYSTEM SHOCK with your mouse (USB?) and keyboard (USB) do both the mouse and keyboard function correctly with SYSTEM SHOCK running at normal speed? If you WAIT to startup SYSTEM SHOCK so that it runs quite slowly, what happens to your mouse and keyboard? Does the mouse function properly and the keyboard fail to respond at all in the menu or in-game? Very important to know this...
You pretty much answered my test questions when you outlined that if you just started an NTVDM session/window right away, but did NOT startup SYSTEM SHOCK very quickly at the same time - that the delay proves fatal in that SYSTEM SHOCK will then respond slowly when it is started in that same NTVDM window because of whatever is happening with the startup programs. It has to be a device driver that is dynamically loaded by an application...
OK, now for the simple test that I would like for you to conduct. I have attached a file to this message called SLOWDOS.ZIP - this file contains the file SLOWDOS.COM (version 1.01) which is a simple DOS TSR written by Mr. Jeff Leyda which plays with the RTC and 8259 PICs on a real DOS system to attempt to control apparent 'speed'.
What I would like for you to attempt to so run this program as an NTVDM 'Dos" prompt with the Command-line of: SLOWDOS /d95 . Please try it in two cases.
First case, do the re-boot and startup the "quick" working NTVDM window in which you are able to successfully run SYSTEM SHOCK, but don't run the SYSTEM SHOCK file CDSHOCK.EXE, instead run SLOWDOS /d95 in its place, just as quickly. What should happen? Nothing, it should have no effect in an NTVDM sandbox. Run some DIRs etc, the speed in the NTVDM should remain the same.
Second case. Wait for all the startup programs to finish so that you now can start an NTVDM window which will FAIL to properly run SYSTEM SHOCK. Don't run CDSHOCK.EXE, instead run the SLOWDOS /d95 command and tell me what happens. Just so you know, technically the NTVDM sandbox should prevent this 'bare-metal' code from doing anything, but if it does BE PREPARED that you MIGHT have your entire WinXP operating system brought to a standstill if any device drivers have given SLOWDOS.COM free reign. I was suprised when it happened to my WinXP (SP2) workstation one time - the system and GUI responded like molasses in the arctic... Had to re-boot to recover functionality. Nothing wrong, but make sure that you don't have anything important open when you perform this test.
Thanks for your time,
dvwjr
