Covox Sound Devices
Reply 20 of 26, by Great Hierophant
matze79 wrote:
Making a internal ISA Covox hmm, is it enough to hook up a Latch to LPT Base Adress ?
Or do they use additional parts ?
The Sound Master also has those parts.
Reply 21 of 26, by borichka
I wonder if someone managed to find the original software for external Covox Master Key System II?
Reply 22 of 26, by Jo22
Hi. Not sure if this the right spot to post, but I found another Covox schematic.
At its core, it uses the usual 20k+10k resistor design, but it also has an LPT-powered amp.
http://rayer.g6.cz/elektro/covox.htm
Also linked is a program called CovoxMP3..
Reply 23 of 26, by Benedikt
Jo22 wrote on 2020-08-06, 13:38:
Hi. Not sure if this the right spot to post, but I found another Covox schematic. At its core, it uses the usual 20k+10k resisto […]
In that context you might also want to take a look at my SoundJr replicas. The schematic and layout files are on github.
The SoundJr devices provide volume control and are actually quite loud, especially for something that is port-powered.
Reply 24 of 26, by Jo22
matze79 wrote on 2018-07-08, 14:29:
Making a "internal" ISA Covox hmm, is it enough to hook up a Latch to LPT Base Adress ? Or do they use additional parts ? […]
All detailed PCBs of the Sound Masters and Voice Masters have a 74HC373 8-bit Latch and a resistor pack which can be used for Speech Thing output. I assume the Sound Master also has one
An internal Covox already exists.
It was made by a German guy at an university and used a real DAC chip (C560 type)
from former East-Germany..
Link and picture : Re: Covox speech thingy!!!
Edit: A real LPT port isn't even required.
You can change the interrupt vectors that BIOS sets up for LPTx..
That way, you can design your Covox interface to appear at a different location by default.
All it needs is a little batch file and debug.exe .
Reply 25 of 26, by Jo22
Speaking of basic Centronics / LPT interfaces..
One of our forum members (133MHz) wrote a fascinating article once about a Famicom/NES clone with word processor and minimalistic parallel interface:
https://133fsb.wordpress.com/2010/03/21/famic … port-interface/
https://hackaday.com/2010/09/30/printing-from … clone-computer/
That being said, I don't know how much of this is applicable to the PC/XT platform.
A simple bus interface/address decoder might be needed, too.
Edit: @Benedikt Thanks a lot, I'll have a look at it. 🙂
Reply 26 of 26, by matze79
Jo22 wrote on 2020-08-06, 14:27:
Edit: A real LPT port isn't even required. You can change the interrupt vectors that BIOS sets up for LPTx.. That way, you can d […]
Already tested a few months ago 😀
works flawless.
but i remember some software won`t like it and go instead with hardcoded addresses.
