Warcraft 2 install error
Reply 20 of 27, by clikc
ok, so its installed, u guys rock, but how do i get it to go full screen if possible, and how do i run it after closeing it?
EDIT
ok, so now its stateing that i don't have a warcraft cd in the system, i've read about this on other sites, but didn't find a fix, any suggestions?
thanks a million
Reply 21 of 27, by ErikGG
The Illegal command could have been the cause of a typo like "instal" or something.
Edit :
To Exit DOSBox you need to type the command Exit.
To make it fullscreen you need to edit the conf file with notepad and edit the SDL parameter fullscreen.
For the problem with the CDRom, use the mount command with -ioctl -t cdrom (see the readme.txt)
Erik.
Read the new FAQ.doc
Reply 22 of 27, by MiniMax
Rank Moderator
Moderator
You did notice the file aptly named README.TXT? As in Read-Me.
_________________
Reply 23 of 27, by clikc
ok, so i'm not fidning anything useful in the read me, did you mean your Dosbox read me, or the one for warcraft? all i need to know is how to make it see the cd when i click single player and i can probabaly figure out how to make it start later
Reply 24 of 27, by ErikGG
Read my edit above,
It is the readme.txt delivered with DOSBox he is mentioning.
Erik.
Reply 25 of 27, by wd
Rank DOSBox Author
DOSBox Author
Both.
And look BEFORE posting.
Reply 26 of 27, by clikc
Both.
yea if he edits it then you can't really look before posting, -_-
Edit
thanks Erik
i got it past the asking for a disc by changing up the command, i can play and am very happy i love these old RTS games, my only concern is when i open dosbox i have to remount the drives, am i going to have to do this every time? and if so is it gonna save my game progress?
thanks Erik u helped alot
Reply 27 of 27, by wd
Rank DOSBox Author
DOSBox Author
README, CLOSED.
