Mechwarrior in DOSBox 0.72
Reply 20 of 27, by hunzababy
haha...i found what causes the crash. Change mpu401 = none....by default is mpu401 = intelligent
Reply 21 of 27, by hunzababy
Change mpu401=uart.....it works now. stupid intelligent not intelligent enough. 😜
Reply 22 of 27, by Qbix
Rank DOSBox Author
DOSBox Author
what are the sound settings you selected for the game ?
Water flows down the stream
Reply 23 of 27, by hunzababy
i did not set any sound setting. the midi is the one that cause the crash though i think. How do i see the sound setting?
Reply 24 of 27, by wd
Rank DOSBox Author
DOSBox Author
installer, setup.exe, menu screen configure, something that's used to change the configuration of the game
Reply 25 of 27, by krzywolf
I am new to dosbox and the mechwarrior game crashes after the mission and was reading on here and it said to change the mpu401=urat or mpu401=none? and my question is how do you change the mpu401?
Reply 26 of 27, by MiniMax
Rank Moderator
Moderator
You have 2 options:
Just before you run the program inside DOSBox, give the 3 commands
mpu401
mpu401=uart
mpu401
or you can go to the folder where you installed DOSBox and change it by opening dosbox.conf with Notepad. Then start DOSBox and check that the changed worked by giving the command
mpu401
_________________
Reply 27 of 27, by lightmaster
i guess he first must create the conf file with the config command..
