I made some trials with 50, 250 and 500 cycles. Results are just the same. Here an exerpt of the log with 50 cycles:
10003490.891 [10057098] rx interrupt off.
10003490.891 [10057098] read 0x50 from RHR.
10003490.945 [10057098] rx 0x47 (G)
10003490.945 [10057098] rx interrupt on.
10003491.091 [10057098] Directserial: block on continued rx (retry=0).
10003491.200 [10057098] write 0x 0 to THR.
10003491.200 [10057098] tx interrupt off.
10003491.200 [10057098] tx 0x00 (0) [FIFO= 1]
10003491.255 [10057098] tx interrupt on.
10003491.291 [10057098] msr interrupt off.
10003491.291 [10057098] read 0x18 from MSR.
10003491.455 [10057098] read 0x21 from LSR.
10003491.527 [10057098] tx buffer empty.
10003491.564 [10057099] rx interrupt off.
10003491.564 [10057099] read 0x47 from RHR.
10003491.600 [10057099] rx 0x39 (9)
10003491.600 [10057099] rx interrupt on.
10003491.764 [10057099] Directserial: block on continued rx (retry=0).
10003491.855 [10057099] write 0x 0 to THR.
10003491.855 [10057099] tx interrupt off.
10003491.855 [10057099] tx 0x00 (0) [FIFO= 1]
10003491.909 [10057099] tx interrupt on.
10003491.964 [10057099] read 0x10 from MSR.
10003492.000 [10057099] rx 0x30 (0)
10003492.000 [10057099] with error: framing=0,overrun=1,break=0,parity=0
10003492.000 [10057099] rx overrun (IF=1)
10003492.000 [10057099] rx 0x2e (.)
10003492.000 [10057099] rx 0x32 (2)
Is it still too fast?
