Confused about some DOSBOX groundrules
Reply 20 of 29, by Aaron H
You guys have been great; now the only thing I want to do is to automate the entire mounting process, so that I don't have to enter:
Z:\> mount C C:\QA
Z:\> C:
C:\> QA
In other words, I want my QA program to open when I click on the DOSBox icon on my desktop. Can you please show me how to do this using DOSBox.conf? (I don't know how to enter those commands in the autoexec section of DOSBox.conf)... 😕
Reply 21 of 29, by Zorbid
Just paste them below the [autoexec] tag, at the end of the file.
Reply 22 of 29, by Aaron H
With or without the Z:\> and C:\> ???
Reply 24 of 29, by Aaron H
Dominus wrote:
without, exactly as if you'd entered them on the prompt: mount C C:\QA C: QA […]
mount C C:\QA
C:
QA
Works great!!! ....just one more request:
When I exit QA, it returns me to the C-prompt (C:\>). Is there any way to have it exit directly to my Vista desktop?
Reply 26 of 29, by gidierre
and that's still another thing :
to do it you can write the .conf file you feel fit, call it my_own.conf
then run the link using the -conf my_own.conf switch
and you're done, it goes like that
pretty simple, you can prepare multiple configurations if you like 😀
Hey, there's one thing I wanted to add ever since your first post, about your Question #3:
the autoexec section makes for a perfect batch replacement to start with, doesn't it, but if you need some more afterwards, I guess you can't write a bat file in dosbox, you can't use edit.com or so afaik,
but you can prepare your tailored batch in Windows, be sure to put it in the soon to be mounted dir you choose and then you can call it from dosbox and it ought to work
(as long as you take care not to mess with the paths... 😉 )
Reply 27 of 29, by Aaron H
DosFreak wrote:
Add exit after QA.
That worked as well. 😎
Thanks!
Reply 28 of 29, by Aaron H
A big thanks to all of you helpful guys for getting me through this. I sure hope this thread proves useful to other noobs (like me)!
Aaron
Reply 29 of 29, by jal
Aaron H wrote:
Would you please give me the procedure for doing that? My commands are as follows:
I think it's already sorted out? Anyway, you already edited your config file so you know how to do that. Just put the lines you listed beneath the [autoexec] section. They will be executed after DOSBox starts.
JAL
