a problem
Reply 20 of 29, by MiniMax
Rank Moderator
Moderator
Which operating system abyss? Win98? WinXP?
What happens to the screen if you go to Start => Run.. => command
Do you get a window that says something like
C:\WINDOWS\system32\command.com
in the title?
What happens if you press ALT-ENTER when command.com is running?
_________________
Reply 21 of 29, by abyss
I'm using xp.
Reply 22 of 29, by MiniMax
Rank Moderator
Moderator
1 out of 3.
_________________
Reply 23 of 29, by dh4rm4
Isn't this is something better served on a general technical support forum?
Reply 26 of 29, by meter98collector
abyss: Thanks for the hardest laugh I've had in ages!
Seriously, start here: Start -> Control Panel -> Display -> Settings tab, then somewhere in that option panel (under Monitor or Advanced, even) there HAS to be a screen rotation option.
Reply 27 of 29, by abyss
Thank you so much. The problem is fixed. Now I got a faulty c drive error on my pentium 1 computer. This computer finally works perfectly again but now the pentium 1 has a faulty c drive. There is an d,e,f, and even a g drive for a reason though and I can just reinstall windows on one of those. I have the cd as the h. Thanks for fixing every computer problem I have. The Pentium 1 problem is nothing bad. I can just install windows 95 with the windows 95 floppy disks on the d drive or e drive or f drive or maybe g drive.
Reply 28 of 29, by Kreshna Aryaguna Nurzaman
The level of patience in this thread astounds me.
Kreshna Aryaguna Nurzaman.
Reply 29 of 29, by dh4rm4
Me too. It's not even in the appropriate forum.
