Reply 20 of 21, by cdeval
You're a boss !
It's perfect now ! 😊 😊
The two parameters are correctly received by the program "probleme.exe"
I suppose the issue will be added to the next version 0.73. I will wait this version because I want to provide an installer of this dos program with inno setup.(It's a free program for learning maths at school.)
Thank's a lot.
PS : Just another minor default, but perhaps dosbox is not reponsible : a square around the mouse cursor is not refreshed when screen change in it. I join you a file showing the default. There is 3 little squares in the middle of the screen. They should be blank and they are not.
The problem not occurs when I run the program with XP command line.
Thank's again for your (quick) help.
