Serial Port question
Reply 20 of 23, by derrickwhitt
Thanks everyone for the help. I downloaded the dosbox build and will try it
Reply 21 of 23, by derrickwhitt
I downloaded the build, and still received the issue. I may just use an old PC
Reply 22 of 23, by DBarzo
Hi,
I have the same issue but with different problem.
I have to read an old radio and I get this error on the status window:
Serial1: Errors occured: Framing 1, Parity 0, Overrun 0 (IF0:0), Break 0
I work with W2000 SP4 with no USB-232 converter.
I have tested it with DosBox 0.72 and with the latest build (01/01/2009)
Where could be the problem?
In attach there are the errors.
Tnx.
Daniele.
Reply 23 of 23, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It's most likely because DOSBox is not realtime capable.
1+1=10
