Reply 20 of 21, by prophase_j
- Member
Yeah it really tears me because on one hand if I invest some more money into my K7 rig then I should be able to hold down a cool 2ghz. Even though P4's have more bandwidth, all of the older stuff I plan to run on it will be as fast if not faster. Athlon's are very bandwidth efficient. So until you start throwing gobs and gobs at the GPU, it won't make a difference. Then there is the other side of the coin, getting a P4 board with an ISA slot, and a 3ghz northwood chip. It would not only catch up to the K7 for legacy, on modern code the K7 would be outclassed.
But yes you should get get that sandra stuff out... I'll upload my version if ya need. You should also measure that fx5950 with 3dmark2k1 😀
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
