Reply 20 of 55, by Shed
 - Newbie
i like DOSBox name
but if Qbix or Dosfreak want a new name i't would call it
PC - D.O.S or PC-DOS 2.0
or PC2DOS
i like DOSBox name
or PC2DOS
DOSBox is a perfectly fine name. Runs DOS in a BOX, works, and is easy to explain. I just do not see the need to change it.
Or maybe "VirtualDOSCompuGlobalHyperMegaNetPCEmuBox"
VDOSPC ? 😮
x86Box
ia32Box
pcBox
Qbox (Qbix may like that one 😁 )
I'd advise against something like doz, since people will make typos galore, thinking is it s or z.
Virtual7Dos, welcoming the brand new Windows 7.
"But listen to me brother, you just keep on walking, 'cause you and me and sister ain't got nothing to hide..." - Scatman John
wrote:i like DOSBox name […]
i like DOSBox name
or PC2DOS
I would steer clear of this considering the company that made PC DOS to begin with is still around, it would only invite a lawsuit.
Its too late to change the name, its been used for years, everyone knows what it is. Everyone would be saying "DOSsuperspecialversion formerly known as dosbox"
But if it did change 😈  maybe something like: DOS4ALL
Just imagine all the people asking about the difference between DOSBox and DoZBox at this Board. Then remember posts like "You'd better use 0.65". After these two scary thoughts you will not want to change the name any longer.
wrote:Since QBix mentioned changing the name of DOSBox in the SourceForge Project of the Month interview
Honestly I really like the name Dosbox. Basically I would think you would want to convey three concepts:
1) It's DOS
2) It's for games
3) It's emulation
So DosGameBox? =) Dunno, but still I would say my recommendation would be stick with Dosbox.
-Frob
If it is just because it is getting beyond DOS, I like the name PC-Box.
But if a change really is desired (it is?), certainly it would need a long transition period, with stuff like "XYZ-Box, dosbox edition" or something like that.
When you look at the OP you will see that this whole "discussion" was caused by the interview qbix gave. I don't think it is actually desired and this thread is just for fun 😀
wrote:If it is just because it is getting beyond DOS, I like the name PC-Box.
Oh yeah, XYZZYBox
Nothing happens.
_________________
Compared to the original list Dosfreak put up, DOSBox is probably the best and most memorable of the bunch.
I use a lot of those other emulators, but always thought DOSBox was the best named of them. I think Nicola probably wishes he named "MAME" something different. 😜
wrote:Okay - I just got a crazy idea! Since DOSBox per default starts up on the Z-drive, how about DOZBox? Or Z-Box?
Just 'Z:'
Klimawandel.
I don't think the name should change either. It's well-established and also describes its main use at the moment (I used to talk about making a real DOS box to play old games on, but DOSBox saves me from the hassle).
If it did need to change, then maybe OldBox, x86box (xbox86 🤣), PCBox...
I prefer "DOSBox" too.
RTFMBox 😁
"What's a paladin?!"
