File access log
Reply 20 of 23, by wd
Rank DOSBox Author
DOSBox Author
Changes to the readfile function (error handling for read() ) may be tricky though.
As you'd have to check lots of functionality like when it's really an error or
just eof and what error code you forward to dos.
Reply 21 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
no error checking.
Only checking the stored file flags for wether it is read_write or read. inside LocalFile::Read
Water flows down the stream
Reply 22 of 23, by Qbix
Rank DOSBox Author
DOSBox Author
we should be checking what cdroms do though. mscdex might mess around with the flags
Reply 23 of 23, by wd
Rank DOSBox Author
DOSBox Author
A cdrom's file open command should reject write-only calls any way, but only mscdex knows for sure.
