Reply 20 of 24, by prophase_j
- Member
wrote:wrote:I have also replaced the AWE64 with an original Sound Blaster 16 that isn't even PNP capable, MIDI is much better now!!!!!!!!
Is that possible? Do i need to swap my 64 out for a 16? I'm gonna have to do some sound tests.
Must be listening listening to FM synthesis. That's the only way your going to get any MIDI music out of the SB16, unless you have a daughterboard or external synth. AWE 64 uses an emulated OPL3, whereas the SB16 likey has the real thing. So correct me if I'm wrong, if your using the EMU part of the AWE and think the patchset sounds worse, or whatever the case.
"Retro Rocket"
Athlon XP-M 2200+ // Epox 8KTA3
Radeon 9800xt // Voodoo2 SLI
Diamond MX300 // SB AWE64 Gold
