Carmageddon splat pack direct draw error
Reply 20 of 29, by Zaxxon
ok i managed to make it start under dosbox with that bosbox build made by ykhwong,problem is that it starts,i see the 3dfx spinning logo,then its all black though i can hear the intro and the main menu sounds.it has something to do with the glide.dll?
Reply 21 of 29, by filipetolhuizen
Same thing happens here, that's why I told it's tricky as it's the furthest I got.
Reply 22 of 29, by robertmo
you have to use dgvoodoo together with that dosbox
Reply 23 of 29, by filipetolhuizen
When I use dgvoodoo with this dosbox, all games crash it.
Reply 24 of 29, by Davros
do you also use glidos ?
Reply 25 of 29, by filipetolhuizen
Haven't tried yet, because when I first used it long time ago it had that annoying spinning logo.
Reply 26 of 29, by Davros
you need dosbox -- glidos -- dgvoodoo for it to work
and the logo is because your version wasn't registered
Reply 27 of 29, by filipetolhuizen
I can get any wrapper to work with VDMSound but not with DOSBox (the version that supports wrappers).
Reply 28 of 29, by Davros
is that with glidos ?
Reply 29 of 29, by filipetolhuizen
I'll also try it.
