Reply 20 of 46, by digitaldoofus
- Member
To follow up on my earlier mention of the X-rated "screen saver" that I own: I wonder if it would be difficult to write a program (or to modify an existing screen saver program) to cause it to come on (no pun intended) "automatically" when the PC has not been in use for, say, 5 minutes?
You see, this X-rated "screen saver" is merely a COM file that must be clicked in order to initiate the animation. Subsequently, any key press (but not mouse movement) will halt the animatiion and return the user to the previous screen as before the animation was triggered.
Any thoughts from some of you programmers out there?
Once you go retro, you'll never go back...
