Data Expert EXP4044 and PC Partner VX
Reply 20 of 25, by Tetrium
h-a-l-9000 wrote:
Uhm such a battery will start leaking whenever it wants, even when not conected.
ugh -_-. Well I'd better flip the board upside down then haha 😜
Reply 21 of 25, by Mau1wurf1977
The simplest solutions are often the best 🤣
Reply 22 of 25, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Too bad the stuff creeps along surfaces
1+1=10
Reply 23 of 25, by DonutKing
🤣 there was a guy at OCAU who was giving me crap for connecting an external battery to my 486 board, he wanted me to buy another barrel battery and solder it on... aside from being a huge pain in the arse to change the battery, when it leaks it gets all over the board... at least the external ones can be mounted somewhere so that if they do leak, it won't be all over anything.
Takes all kinds I guess.
Personally I don't trust ANY of those barrel batteries, I've seen too many boards destroyed by them. The biggest worry is the corrosion you don't see, below the surface of the board.
Anyway, if you are looking for another sound card, I have a few Vibra CT2800's which are just like a normal SB16 except with much higher sound quality (in my experience anyway) plus they have real OPL3 chips. I'm using one in my 486 now. Seems to drive the MT32 alright as well. Could probably spare you one if you want it.
Reply 24 of 25, by SquallStrife
Hmm, I might take you up on that! 😀
Reply 25 of 25, by RayeR
Hi, do still someone own the EXP4044 MB?
I have one to repair and it's also missing VRM components beside CPU socket. Can you read the marking on components Q1A, Q1B, Q1?
