Reply 20 of 20, by Jolaes76
Jolaes76
Offline
Okay, here is what I have found.
Xwing (floppy version) must work with an MPU IPC-T fine.
It is, however, more sensitive to machine speed than some other games from 1991-1993. I had to disable both internal and external cache in BIOS and fall back to 2x100 Mhz. At this speed, I played cca. 40 minutes, did not come across any MIDI errors.
With cache enabled, MT-32 gen. 1. hangs and freezes with an "Exc. Buffer Overflow" message.
Laser Squad, Spellcasting series worked just fine with cache enabled at 200 Mhz.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
