Things you will never own, but want to.
Reply 21 of 47, by sliderider
Tetrium wrote:
I forgot to add, I'd die to get me hands on a Socket 3 ATX board! 😁
Do those even exist? If there's an ATX 486 motherboard at all I would think it would be Socket 6. I've never seen even a late PCI 486 motherboard that was in ATX configuration and used an ATX PSU.
Reply 22 of 47, by Tetrium
I very much doubt such a board exists, even though (looking back) there was "an" opportunity for manufacturers to produce one, but none of the manufacturers actually went through the effort to build one 🙁 🙁 🙁
Afaik the oldest ATX board was made by Intel and comes with a VX chipset.
I wish they existed though, such a board would've been A-WE-SOME!!!11 ;D
My retro rigs (old topic)
Report spammers here!
Reply 23 of 47, by Dant
SavantStrike wrote:
Or an attractive 8 or 10 bay AT case with a three piece side panel design rather than the single U shaped side panel that is oh so common, and at a price that doesn't cost a fortune. And I mean true AT, not just ATX that supports AT.
Ask, and you shall receive.
http://cgi.ebay.com/10-BAY-FULL-TOWER-SERVER- … =item51939ec0fd
I personally would kill for one of those NCR Worldmark 4380s
That's an 8-CPU PPro machine that can take up to 8GB of EDO DIMMs and has 10 or 15 PCI slots and 4 EISA slots... Good enough? I've found where NCR seems to be selling some old stock of them... but it's not completely worth the 10 grand they're asking for it...
Reply 24 of 47, by schlang
for those of you looking for sound cards, check this thread on a regularly basis: http://www.vintage-computer.com/vcforum/showt … e-Tracker/page7
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 25 of 47, by SavantStrike
Dant wrote:
Ask, and you shall receive. […]
Good gracious thats huge!
Tempting though...
Reply 27 of 47, by Old Thrashbarg
Wow, that's one of the rare few cases that even support the weird extended AT boards, like these beasts... notice the four slots above the keyboard hole.
Reply 28 of 47, by SavantStrike
That board is obnoxious...
NT/2k glide rig with one of the Quantum3d Cards with twin Voodoo Graphics maybe. It's kind of a shame though with 6 ISA slots. It demands Win9X or DOS as well. One could populate that with some serious sound cards.
Reply 29 of 47, by luckybob
Just like the P65up8 board that I will never have.
Reply 30 of 47, by swaaye
SGI InfiniteReality. 😀
Voodoo 5 6000
Matrox G800
3DO M2
Reply 31 of 47, by SavantStrike
swaaye wrote:
SGI InfiniteReality. :-) […]
Voodoo 5 6000
Matrox G800
3DO M2
*drools*
I cannot fathom how much it would cost to run such an animal though.
But the M2. Now that's a good one! Weren't there some stripped down kiosks loosely based on the design?
Reply 32 of 47, by swaaye
Yup the M2 hardware was finished but Matsushita decided not to turn it into a game console after all. Probably a good move considering it would have come out around when Dreamcast showed up and been completely blown away by it.
There are a few arcade games that used it but otherwise it was only used for kiosks as you say.
http://www.videogameconsolelibrary.com/pg90-3do2.htm
http://nfggames.com/games/polystars/
http://www.system16.com/hardware.php?id=575
Reply 33 of 47, by Dant
I would agree with you, but it's a Dual Socket 5 board, so it maxes out at 180MHZ with MMX overdrives...
Sad
I went back and read the opening post more closely, that thing is beastly!
Also, Since when is there a chipset that supports Socket 7 AND Socket 8 AND Slot 1... AND SMP at that!!?!?
Reply 34 of 47, by luckybob
Dant wrote:
Sad
Its because the north-bridge is on the cpu card. The south-bridge is on the motherboard and it was designed to accept any 440 class north-bridge.
Also, socket 8 and slot 1 and by extension socket 370 are all electrically compatible. I have a pair of socket 8 to slot 1 adapters. Its a shame the Pentium pro refuses to work with agp otherwise I'd put them in my Asus p2b-ds. 😜 I can get the board to post with the p-pro but the bios freaks out and doesn't know what to do so it crashes.
And while we are on the subject. The socket 8 to slot 1 adapters are HELL to find.
Reply 35 of 47, by sliderider
Dant wrote:
I would agree with you, but it's a Dual Socket 5 board, so it maxes out at 180MHZ with MMX overdrives... […]
Sad
Sounds like the perfect motherboard for a Bitchin' Fast 3D.
Reply 36 of 47, by Dant
I knew about Socket 8, Slot 1, and Socket 370 being almost identical. Interesting they went for that kind of design.
Since the 440FX northbridge could drive Socket 8 and Slot 1 CPUs, Does it use that for both Slot 1 and Socket 8 or (Hopefully) does it use a 440BX for Slot 1?
The reason AGP doesn't work with PPros and Socket 8 Slotkets are so hard to find is that only one Slot 1 chipset supported them, the 440FX which didn't support AGP.
The P2B-DS is a 440BX board (Proud owner of a P2B-D)
Reply 37 of 47, by sliderider
Dant wrote:
I knew about Socket 8, Slot 1, and Socket 370 being almost identical. Interesting they went for that kind of design. […]
That's weird seeing a Slot 1 motherboard without an AGP slot. Google for pictures of the Shuttle HOT-623, the ABit AN6, AOpen AX6F and the Tyan S1682. Was 440FX a server chipset?
Reply 38 of 47, by Chewhacca
I ordered an 8-bay from those guys in May and it still hasn't arrived yet.
Reply 39 of 47, by swaaye
440FX is the desktop/workstation chipset for PPro and Klamath PII. It was primarily for Pentium Pro but was used for the Klamath PII chips for a short while until 440LX came out.
