Tetrium wrote:I'm not sure what affects them, but I do know I once got a working GF2 Pro. Over 3 years ago I put one of those big blue Zalman  […]
I'm not sure what affects them, but I do know I once got a working GF2 Pro. Over 3 years ago I put one of those big blue Zalman heatpipe coolers on it (didn't really have any better graphics cards to mod back then) and put it away as I never had a suitable system for it, then kinda forgot about it.
Then recently I found it again. It had 2 bulging caps -_-
I'm 100% sure these weren't bulging back when I originally installed the cooler or I wouldn't have bothered putting that cooler on it in the first place.
I noticed the same with 1 (maybe 2) motherboard, a BX slot 1. It appeared to have started bulging after I got it as I never accept bulging caps on any PCB.
..message goes blank when posting it WTF?!
!  😲  EDIT; it was the 'url' coding that killed it, somehow my url works without the [ url] coding! (space intentional not to kill this message)
Removed the coding, bare url only, and am now able to post here!... weird.
pewpewpew wrote: Online, look to ham radio restoration. Those guys are already having serious discussion about these issues.
Thanks for the tip !!! Saved my day!  😁  (well, kinda, heh...)
So, it seems like drying out is not the only or even worst problem.....
I KNEW I had heard a rumour about 'the badness of idleness', just couldn't find any more info...
That may explain why my daily working slot1 mobo still works, while some of the ones in storage take several tries to start, or even not at all....  😒
http://www.nmr.mgh.harvard.edu/~reese/electrolytics/
excerpts:
"Electrolytics do not suffer idleness well. They can cause big trouble when idle for long periods, needing periodic charging to stay "formed" and maintain the oxide layer that insulates the conducting plates. Sometimes they can be "reformed" by a slowly rising return to working voltage (see below). Even with regular use, electrolytics fail with age by drying out or leaking electrolyte following internal corrosion. If the electrolytic bulges, shows obvious loss of electrolyte, or simply can't be reformed you must replace it. "
and...
"Reforming
The thin layer of aluminum oxide formed to insulate the capacitor foil constitutes formation. Capacitor manufacturers use proprietary mixes of chemicals and DC electricity to create this insulating layer, which deteriorates with time and idleness. Often the oxide layer is in such bad shape in older equipment that it must be reformed or else the capacitor will fail catastrophically. All methods of reforming use the slow reapplication of DC electricity to restore the oxide layer to its original thickness and uniformity.
 In my opinion, there's no one proven way to reform - many different approaches are available, but all have one element in common - slowness. The reforming must proceed faster than the buildup of heat due to the low resistance of the faulty oxide layer - this will at least take hours, and can take days."
MAn...  those of us that has several(or several dozen++) of mobos etc, will have to rotate them in some sort of power-up period, weekly/monthly/yearly ??!
(IF I understood it correctly that is....  😜 )
How often, and how long each time??
hmm... More research/netsearch needed....
NOTE: I am assuming that the same science applies for 'new-er' smaller computer caps vs those older audio/radio ones, common factor beeing the electrolytes, so....
edit2:
crap, I forgot, even CRT's have loads of the stuff/caps inside.... but they are such a pain(30kg) to move out of storage and 'recharge'... ack
Cannot permanently fill the living room with 6 spare ones either.
