noshutdown wrote:MaxWar wrote:Did you have the oppotunity to try Power YMF yet ? […]
Ace wrote:Yeah, I just downloaded Power YMF and will give it a go on the YMF724 later today.
I just finally installed my ymf724 on a win98 box, i used VxD drivers that i found on the net. Works pretty well, i tested both GM and OPL3 compatibility and all looks good however i feel like the output level is somewhat low but ill do more testing.
I still have to make it work under dos and its a bit annoying to work on this rig atm as it does not have the net, could not get a Nic driver to work on it...
Will try to grab a bunch of NICs at my E-recycle guy this week end, i can only do so much with floppies and cds...
which model is it?
output level is somewhat low depends on whether it has an onboard amplifier ic. if it doesn't, you would need an external amplifier.
Heres my card :
Ive been messing around with it for a while here and the output for regular sound and GM is perhaps a little low, but its not too bad. ITs the OPL3 music that seems low.
To give you an idea, i am outputting into a mixer that goes into my sound system. I use some VxD drivers in win98, i set master output and midi out in Windows to Max. I set music volume in a given game to Max. I set Trim on my mixer input to 90%, track volume to 100% then i set Master at about 90% and my level is just ok, as in just below peaking.
I do not know if using another driver or editing some hidden file would give me access to OPl3 sound volume or something. It works all right, but consequence of having to boost everything like that is the Signal to noise ratio is not at its best. I still got to say its surprisingly not too bad considering all the boosting im doing on it LoL.
