Reply 20 of 22, by rcblanke
Again, I have nothing against the new rules on where which file ought to go.
Reply 21 of 22, by yannara
Is there any switch or command line for dosbox.exe to force to use dosbox.conf which is located in the same folder? I´m still having a problem that dosbox for some reason uses .conf under user profile.
Fan of Doom, Mortal Kombat, Duke, Blood
Reply 22 of 22, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
If you don't set the start directory to the dosbox folder it may not work. The readme does list the commandline options...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
