Gorilla the old time pal
Reply 20 of 21, by robertmo
you can adjust cycles manually with ctrl-f11 ctrl-f12 while dosbox is running
Reply 21 of 21, by idspispopd
aeronix wrote:
@idspispopd
Setting the cycles helped. Are the game codes freely available? As I suspected earlier there was some settings which needed to be adjusted.
Look again, I posted a link to the source code., which I got from the Wikipedia article I also linked.
And of course it should be included with MS-DOS 5.0 along with the QBasic interpreter you'll need.
