Reply 20 of 55, by elianda
- l33t
wrote:Thanks for all the feedback folks. It seems like a very nice CPU for the mid-1990s, with most games of the time running nice and smooth (except for GLQuake). But how come it gets less FPS in GLQuake than the software version? Didn't GLQuake get 30 fps even on Pentium 100? Are you running Jedi Knight accelerated or unaccelerated?
Also, elianda, did you run UNIVBE for this test? And can you try running Quake II in software mode in 320x200 please? What resolution did you run Quake II accelerated here?
Does anyone here have Descent 2 by any chance? FPS testing there would also be easy, just type in "frametimer", without brackets of course.
I did not benched GLQuake. I also did not run UNIVBE as it doesn't help anything. It might even slow everything down.
The resolution is the same as shown in the Quake2 framegrab, 640x480. I can of course also run it in 320x200 if the windows driver supports low resolutions.
I have Descent 2 somewhere but as I wrote I benched only stuff that was installed on the hdd I used.
Youtube Channel
