Reply 20 of 23, by Coastal
Jorpho Wrote
"Did you only change the attribute for that one file? Were there no other files that had the read- only attribute?"
The Login file was the only file of the group that is associated with PROTECCT that had a read-only attribute.
I believe I'll try to use one of the VM's you suggested. Do you think one of them might be better for my purpose than the others?
