Reply 20 of 24, by AlphaWing
- Oldbie
wrote:you can buy blank i/o shields on ebay and cut your own openings..
http://www.ebay.com/itm/NEW-SuperMicro-MCP-26 … =item54033d1f42
You can make your own out of the top of a plastic ice cream bucket.
The plastic is more then malleable enough. You can easily cut it to size, and many cases have holes right above the slot for a screw+nut to hold it.
Hot glue is an option too.
Then you can paint it whatever color you want .
Cheaper then spending 15$ on a blank I/O plate + you get a gallon of ice cream to eat 😎
